Киа Рио 1 BC
Сообщений в теме: 10
  • 24962 сообщений
Отправлено 28 February 2021 - 12:04
G 1.3 SOHC > Brake > Anti-Lock Brake
C1101 Battery Voltage High
C1102 Battery Voltage Low Volt
C1201 Wheel Speed Sensor Front-LH Range/Performance/Intermittent
C1202 Wheel Speed Sensor Front-LH Invalid/No Signal
C1203 Wheel Speed Sensor(FR)-Open or Short
C1204 Wheel Speed Sensor(FR)-Range/Performance
C1205 Wheel Speed Sensor(FR)-No Signal
C1206 Wheel Speed Sensor(RL)-Open or Short
C1207 Wheel Speed Sensor(RL)-Range/ Performance
C1208 Wheel Speed Sensor(RL)-No Signal
C1209 Wheel Speed Sensor(RR)-Open or Short
C1210 Wheel Speed Sensor(RR)-Range/Performance
C1211 Wheel Speed Sensor(RR)-No Signal
C1604 ECU(Brake System) Hardware error
C2112 Valve Relay Error
C2402 Motor Electrical
  • 24962 сообщений
G 1.3 SOHC > Airbag > Airbag Control(LHD)
B1111 Ignition Voltage High
B1112 Battery Voltage Too Low
B1347 Driver Air Bag Resistance Too Low or Short
B1353 Passenger Air Bag Resistance Too Low or Short
B1354 Passenger Air Bag Short To Ground
B1355 Passenger Air Bag Short To Battery
B1362 Driver Seat Belt Pretensioner Resistance Too Low or Ghort
B1363 Driver Seat Belt Pretensioner Short To Ground
B1364 Driver Seat Belt Pretensioner Short To Battery
B1367 Passenger Seat Belt Pretensioner Resistane Too High or Open
B1368 Passenger Seat Belt Pretensioner Resistane Too Low or Short
B1369 Passenger Seat Belt Pretensioner Short To Ground
B1370 Passenger Seat Belt Pretensioner Short To Battery
B1379 Driver Side Air Bag Resistance Too Low
B1380 Driver Side Air Bag Short To Ground
B1381 Driver Side Air Bag Short To Battery
B1382 Passenger Side Air Bag Resistance Too High or Open
B1383 Passenger Side Air Bag Resistance Too Low or Short
B1384 Passenger Side Air Bag Short To Ground
B1385 Passenger Side Air Bag Short To Battery
B1400 SIS(Side Impact Sensor) Front-Driver Defect
B1401 Satellite Left Side Short To Ground
B1402 Satellite Left Side Short To Battey or Open
B1403 Satellite right Side defect
B1404 Satellite right Side Short To Ground or Short
B1405 Satellite right Side Air Bag To Battery or Open
B1408 Sattelite Left Communication Error
B1410 Sattelite Right Communication Error
B1620 Internal Fault
B1657 Ignition Recorded Belt Pretensioner
B2500 Warning Lamp Failure
  • 24962 сообщений
G 1.3 SOHC > Engine > Unleaded-MAP
P0107(General) Manifold Absolute Pressure Circuit Low Input
P0030 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P0031 Heated O2 Sensor(HO2S) Heater Control Circuit Low(B1/S1)
P0032 Heated O2 Sensor(HO2S) Heater Control Circuit High(B1/S1)
P0036 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0037 Heated O2 Sensor(HO2S) Heater Control Circuit Low(B1/S2))
P0038 Heated O2 Sensor(HO2S) Heater Control Circuit High(B1/S2))
P0100 Mass or Volume Air Flow(MAF) Circuit Malfunction
P0108(General) Manifold Absolute Pressure Circuit High Input
P0112(General) Intake Air Temperature(IAT) Circuit Low Input
P0113(General) Intake Air Temperature(IAT) Circuit High Input
P0117(General) Engine Coolant Temperature(ECT) Circuit Low
P0118(General) Engine Coolant Temperature(ECT) Circuit High
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0122(General) Throttle Position Sensor(TPS) Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0123(General) Throttle Position Sensor(TPS) Circuit High Input
P0125 Insufficient Coolant Temp. for Closed Loop Fuel Control
P0131(General) Heated O2 Sensor(HO2S) Circuit Low Input(B1/S1)
P0132(General) Heated O2 Sensor(HO2S) Circuit High Input(B1/S1)
P0135(General) Heated O2 Sensor(HO2S) Heater Malfunction(B1/S1)
P0172 System too Rich (Bank 1)
P0201(General) Injector Circuit-Cylinder 1
P0202(General) Injector Circuit-Cylinder 2
P0203(General) Injector Circuit-Cylinder 3
P0204(General) Injector Circuit-Cylinder 4
P0261 Injector Circuit Low - Cylinder 1
P0262 Injector Circuit Hihg - Cylinder 1
P0264 Injector Circuit Low - Cylinder 2
P0265 Injector Circuit High - Cylinder 2
P0267 Injector Circuit Low - Cylinder 3
P0268 Injector Circuit High - Cylinder 3
P0270 Injector Circuit Low - Cylinder 4
P0271 Injector Circuit High- Cylinder 4
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0325(General) Knock Sensor Circuit Malfunction(B1)
P0335(General) Crankshaft Position(CKP) Sensor Circuit Malfunction
P0340(General) Camshaft Position Sensor Circuit Malfunction
P0420 Three Way Catalyst(TWC) System Efficiency Below Threshold(B1)
P0443(General) Evaporative Emission(EVAP) System Purge Control Valve
P0444 Evaporative Emission(EVAP) System Purge Circuit Open
P0445 Evaporative Emission(EVAP) System Purge Circuit Shorted
P0501(General) Vehicle Speed Sensor(VSS) Range/Performance
P0560 System Voltage
P0562 System Voltage Low
P0563 System Voltage High
P0605 ECM Malfunction(ROM)
P0606(General) ECM Malfunction(Processor)
P1166 Feedback System(B1)
P1505 Idle Speed Control Actuator Circuit 1-Low
P1505(General) Idle Air Control(IAC)Valve Opening Coil Signal Low
P1506 Idle Speed Control Actuator Circuit 1-High
P1506(General) Idle Air Control(IAC)Valve Opening Coil Signal High
P1507 Idle Speed Control Actuator Circuit 2-Low
P1507(General) Idle Air Control(IAC)Valve Closing Coil Signal Low
P1508 Idle Speed Control Actuator Circuit 2-High
P1508(General) Idle Air Control(IAC)Valve Closing Coil Signal High
P1586 M/T-A/T Encoding Signal Malfunction
P1693 TCM Malfunction Indicator Lamp (MIL) Request Line Malfunction
  • 24962 сообщений
Отправлено 28 February 2021 - 12:05
G 1.3 SOHC > Transmission > Automatic Transaxle(LHD)
P0713 Fluid(Oil) Temperature Circuit High
P0717 Input/Turbine Speed Sensor No Signal
P0727 Eng. Speed Input Circuit No Signal
P0748 Pressure Control Solenoid "A" Electrical
P0753 Shift Control Solenoid Valve "A"
P0758 Shift Control Solenoid Valve " B" Electrical
P0763 Shift Control Solenoid Valve "C"
P1121 Throttle Position Sensor (TPS) Signal Malfunction
P1500 Vehicle Speed Sensor Signal Circuit Malfunction
P1780 Torque Reduction Request Signal (TCU-ECU)
P1800 Engine Torque Signal Malfunction
P0707 Transmission Range Sensor Circuit Low Input
P0716 Input/Turbine Speed Sensor "A" Circuit Range/Performance
P0726 Engine Speed Input Circuit Range/Performance
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0741 Torque Converter Clutch Circuit Stuck Off
P1700 Over Drvier(O/D) Lamp / Hold Lamp Circuit Malfunction
  • 24962 сообщений
G 1.5 DOHC > Brake > Anti-Lock Brake
  • 24962 сообщений
G 1.5 DOHC > Airbag > Airbag Control(LHD)
  • 24962 сообщений
G 1.5 DOHC > Engine > Unleaded-MAP
  • 24962 сообщений
G 1.5 DOHC > Transmission > Automatic Transaxle(LHD)
  • 24962 сообщений
G 1.6 DOHC > Brake > Anti-Lock Brake
  • 24962 сообщений
G 1.6 DOHC > Airbag > Airbag Control
Ещё обсуждения по киа рио 1 bc на MyKia.club:
