G 1.4 DOHC > Engine > Unleaded EOBD
P0031 HO2S Heater Circuit Low (Sensor1)
P0032 HO2S Heater Circuit High (Sensor1)
P0036 HO2S Heater Control Circuit (Sensor2)
P0037 HO2S Heater Circuit Low(Sensor2)
P0038 HO2S Heater Circuit High(Sensor2)
P0068 MAP/MAF-Throttle Position Correlation
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittant
P0130 O2 Sensor Circuit(Sensor1)
P0131 O2 Sensor Circuit Low Voltage (Sensor1)
P0132 O2 Sensor Circuit High Voltage (Sensor1)
P0133 O2 Sensor Circuit Slow Response (Sensor1)
P0134 O2 Sensor Circuit No Activity Detected (Sensor 1)
P0135 HO2S Heater Control Circuit (Sensor 1)
P0136 O2 Sensor Circuit (Sensor 2)
P0137 O2 Sensor Circuit Low Voltage(Sensor 2)
P0138 O2 Sensor Circuit High Voltage(Sensor 2)
P0139 O2 Sensor Circuit Slow Response(Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Sensor 2)
P0141 O2 Sensor Heater Circuit (Sensor 2)
P0171 System Too Lean
P0172 System Too Rich
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0261 Cylinder 1-Injector Circuit Low
P0262 Cylinder 1-Injector Circuit High
P0264 Cylinder 2-Injector Circuit Low
P0265 Cylinder 2-Injector Circuit High
P0267 Cylinder 3-Injector Circuit Low
P0268 Cylinder 3-Injector Circuit High
P0270 Cylinder 4-Injector Circuit Low
P0271 Cylinder 4-Injector Circuit High
P0301 Cylinder 1-Misfire Detected
P0302 Cylinder 2-Misfire Detected
P0303 Cylinder 3-Misfire Detected
P0304 Cylinder 4-Misfire Detected
P0326 Knock Sensor 1 Circuit Range/Performance
P0327 Knock Sensor 1 Circuit Low Input
P0328 Knock Sensor 1 Circuit High Input
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit
P0340 Camshaft Position Sensor A Circuit Malfunction (Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance(Single Sensor)
P0342 Camshaft Position Sensor A Circuit Low Input
P0343 Camshaft Position Sensor A Circuit High Input
P0420 Catalyst System Efficiency below Threshold (Bank1)
P0444 Evaporative Emission System Purge Control Valve Circuit Open
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
P0506 Idle Air Control System - RPM lower than expected
P0507 Idle Air Control System - RPM higher than expected
P0560 System Voltage
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0600 CAN Communication BUS
P0605 Internal Control Module Read Only Memory (ROM) Error
P1505 Idle Charge Actuator Signal Low of Coil #1
P1506 Idle Charge Actuator Signal High of Coil #1
P1507 Idle Charge Actuator Signal Low of Coil #2
P1508 Idle Charge Actuator Signal High of Coil #2
P1550 Knock sensor evaluation IC
P1560 Knock control SPI check
P1602 CAN Communication BUS with TCU (Timeout)
P2096 Post Catalyst Fuel Trim System Too Lean
P2097 Post Catalyst Fuel Trim System Too Rich
P2232 O2 Sensor Signal Circuit Shorted to Heater Circuit (Sensor 2)
#11
Отправлено 26 February 2021 - 16:29
#12 Re: коды ошибок, расшифровка
G 1.4 DOHC > Transmission > Automatic Transaxle
P0703 Stop Lamp Switch(Brake SW) - Short(+B)
P0712 Transaxle Fluid Temperature Sensor Circuit Low Circuit
P0713 Transaxle Fluid Temperature Sensor Circuit High Circuit
P0716 A/T Input Speed Sensor High Input
P0717 A/T Input speed Sensor Circuit Low Input
P0722 A/T Output speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0741 Damper Clutch Open Stuck
P0742 Damper Clutch Close Stuck
P0743 Damper Clutch Control Solenoid Valve : Open or Short(GND)
P0745 Pressure Control Solenoid Valve-A Circuit - Open or Short(GND)
P0750 Shift Control Solenoid Valve-A Circuit - Open or Short(GND)
P0755 Shift Control Solenoid Valve-B Circuit - Open or Short(GND)
P0760 Shift Control Solenoid Valve-C Circuit - Open or Short(GND)
P0775 Pressure Control Solenoid Valve-B Circuit - Open or Short(GND)
P1709 K/D Switch - Open or Short(GND)
U0001 Can Communication BUS Off
U0100 No ID From ECU
Последние обсуждения по Киа Рио 2 JB на MyKia.club
Киа Рио 2 JB
Киа Рио клуб →
Электрика и Аудио Kia Rio →
схема проводки (жгутов)Автор krionika, 28 Feb 2023 |
Киа Рио 2 JB
Киа Рио клуб →
Кузов и Салон Kia Rio →
напольная консольАвтор krionika, 02 Jun 2011 |
Киа Рио 2 JB
Киа Рио клуб →
предохранители и релеАвтор krionika, 23 May 2011 |
Киа Рио 2 JB
Киа Рио клуб →
блок BCMАвтор krionika, 14 Apr 2004 |
Киа Рио 2 JB
Киа Рио клуб →
Двигатель и КПП Kia Rio →
бензобакАвтор krionika, 13 Oct 2008 |
