Коды ошибок Kia Rio 2 (JB)
G 1.6 DOHC > Airbag > Airbag Control
B1101 Battery voltage too high
B1102 Battery voltage too low
B1328 FIS-Driver defect
B1333 FIS-Passenger defect
B1395 Firing loop interconnection fault
B1400 SIS front-Driver defect
B1476 Pretensioner front-Driver resistance circuit short to Battery
B1527 Passenger airbag deactivation switch open or short to Battery
B1528 Passenger airbag deactivation switch short or short to Ground
B1529 Passenger airbag deactivation switch defect
B1530 Passenger airbag deactivation switch instability
B1659 Rear crash detected
B2500 Warning Lmap
B2505 Passenger airbag off warning lamp failure
