Киа Венга YN
Сообщений в теме: 32
#31 krionika
  • 24085 сообщений
Отправлено 18 February 2021 - 18:56
G 1.6 DOHC > Tire Pressure Monitoring > Tire Pressure Monitoring
C1300 TPMS ECU IRX not responding
C1332 Front Left Sensor Fault
C1334 Left Rear Sensor Fault
C1335 Rear Right Sensor Fault
C1337 Left Front Low Frequency Initiator Fail Pulse Detected
C1338 Right Front Low Frequency Initiator Fail Pulse Detected
C1339 Right Rear Low Frequency Initiator Fail Pulse Detected
C1341 Left Front Low Frequency Initiator Channel Failure
C1342 Right Front Low Frequency Initiator Channel Failure
C1343 Left REAR Low Frequency Initiator Channel Failure
C1344 Right Rear Low Frequency Initiator Channel Failure
C1351 Left Front Low Frequency Initiator Open/Short Failure
C1352 Right Front Low Frequency InitiatorI Open/Short Failure
C1353 Right Rear Low Frequency Initiator Open/Short Failure
C1613 CAN Wrong Message
C1616 CAN Bus Off
C1661 Receiver EEPROM Failure
C1662 Auto Learning failure
  • 24085 сообщений
G 1.6 DOHC > Engine > Engine Control
P0011 "A" Camshaft Position-Timing Over-Advanced or System Performance (Bank 1)
P0016 Crankshaft Position–Camshaft Position Correlation (Bank 1 Sensor A)
P0030 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 / Sensor 1)
P0036 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 / Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 / Sensor 2)
P0076 Intake Valve Control Solenoid Circuit-Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit-High (Bank 1)
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0122 Throttle Position Sensor 1 Signal Circuit Low Input
P0123 Throttle Position Sensor 1 Signal Circuit High Input
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0261 Cylinder 1 Injector Circuit Low
P0264 Cylinder 2 Injector Circuit Low
P0267 Cylinder 3 Injector Circuit Low
P0270 Cylinder 4 Injector Circuit Low
P0301 Cylinder 1-Misfire detected
P0302 Cylinder 2-Misfire detected
P0303 Cylinder 3-Misfire detected
P0304 Cylinder 4-Misfire detected
P0340 Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
P0444 Evaporative Emission System-Purge Control Valve Circuit Open
P0445 Evaporative Emission System-Purge Control Valve Circuit Shorted
P0504 Brake Switch “A”/”B” Correlation
P0557 Brake Booster Pressure Sensor Circuit Low
P0558 Brake Booster Pressure Sensor Circuit High
P0560 System Voltage
P0562 System Voltage Low
P0563 System Voltage High
P0616 Starter Relay Circuit Low
P0617 Starter Relay Circuit High
P0620 Alternator Control Circuit
P0625 Generator Field/ F Terminal Circuit Low
P0626 Generator Field/F Terminal Circuit High
P0638 Throttle Actuator Control Range / Performance
P0642 Sensor Reference Voltage "A" Circuit Low
P0643 Sensor Reference Voltage "A" Circuit High
P0704 Clutch Switch Input Circuit Malfunction
P0820 Gear Lever X-Y Position Sensor Circuit
P2096 Post Catalyst Fuel Trim System too Lean (Bank 1)
P2097 Post Catalyst Fuel Trim System too Rich (Bank 1)
P2101 Throttle Actuator Control Motor Circuit Range/Performance
P2104 Limp Home Mode - Forced Idle
P2105 Limp Home Mode - Force Engine Shutdown
P2106 Lime Home Mode - Force Limited Power
P2110 Throttle Actuator Control System-Force Limited RPM
P2118 Throttle Actuator Control Motor Current Range/Performance
P2119 Throttle Actuator Control Throttle Body Range/Performance
P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low Input
P2123 Throttle/Pedal Position Sensor /Switch "D" Circuit High Input
P2127 Throttle/Pedal Position Sensor/Switch "E" Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch "E" Circuit High Input
P2159 Vehicle Speed Sensor "B" Range / Performance(Wheel Speed Sensor)
P2187 System too Lean at Idle (←Additive) (Bank 1)
P2188 System too Rich at Idle (Bank 1)
P2191 System too Lean at Higher Load (Multiple) (Bank 1)
P2192 System too Rich at Higher Load(Bank 1)
U0101 Lost Communication With TCM
U0155 Vehicle Communication Bus A
U0164 CAN Communication BUS with FATC(Timeout)
U1111 Battery Sensor fault detected by ECU
U1112 LIN Communication Error
  • 24085 сообщений
Отправлено 18 February 2021 - 18:57
G 1.6 DOHC > Transmission > Automatic Transaxle
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0713 Transmission Fluid Temperature Sensor "A" Circuit High Input
P0717 Input/Turbine Speed Sensor "A" Circuit No Signal
P0722 Output Speed Sensor Circuit No Signal
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0748 Pressure Control Solenoid Valve(VFS) "A" Electrical
P0750 Shift Control Solenoid Valve "A" (ON/OFF)
P0755 Shift Control Solenoid Valve "B"(PCSV-A)
P0760 Shift Control Solenoid Valve "C"(PCSV-B)
P0765 Shift Control Solenoid Valve "D"(PCSV-C)
U0100 Lost Communication With ECM/PCM "A"
Последние обсуждения по Киа Венга YN на MyKia.club
