D 1.6 TCI-U2 > Brake > ABS/ESP
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1213 Wheel Speed Frequency Error
C1285 Sensor Cluster Change Detection/Uncalibrated
C1520 Clutch switch
C1527 Gear R Switch Error
C1604 ECU Hardware Error
C1605 CAN Hardware Error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1613 CAN Wrong Message
C1616 CAN Bus Off
C1626 Implausible Control
C1643 CAN Time-out Yaw Rate & Lateral G Sensor
C1702 Variant Coding Error
C2112 Valve Relay Error
C2308 Front-LH Valve error (Inlet Valve)
C2312 Front-LH Valve error (Outlet Valve)
C2316 Front-RH Valve error (Inlet Valve)
C2320 Front-RH Valve error (Outlet Valve)
C2324 Rear-LH Valve error (Inlet Valve)
C2328 Rear-LH Valve error (Outlet Valve)
C2332 Rear-RH Valve error (Inlet Valve)
C2336 Rear-RH Valve error (Outlet Valve)
C2366 TC Valve Primary (USV1) Error
C2370 TC Valve Secondary (USV2) Error
C2372 Electronic Shuttle Valve Primary (HSV1) Error
C2374 Electronic Shuttle Valve Secondary (HSV2) Error
C2402 Motor Electrical
#11
Отправлено 18 February 2021 - 18:54
#12 Re: коды ошибок, расшифровка
D 1.6 TCI-U2 > Immobilizer > Immobilizer
P1675 Immobilizer-Transponder Programming Error
P169A Immobilizer-SMARTRA Authentication Fail
P1692 Immobilizer Indicator Lamp Error
D 1.6 TCI-U2 > Power Distribution Module > Power Distribution Module
B1602 CAN Error
B1603 CAN Bus Off
B1987 Sub Micom Failed
B1988 ESCL Battery Short Circuit To Battery
B1989 ESCL Ground Short Circuit To Battery
B1990 ESCL Battery Short Circuit To Ground
B1991 Immobilizer TX Short Circuit To Ground
#13 Re: коды ошибок, расшифровка
D 1.6 TCI-U2 > Smart Key > Smart Key Code Saving
D 1.6 TCI-U2 > Smart Key > Smart Key Unit
B1602 CAN Error
B1603 CAN Bus Off
B1604 CAN Timeout between SMK and (IPM or BCM)
B1625 ECM Communication Data Failure
B1689 CAN Time-out PDM
B1971 Parking Position Input Error
B1978 Electric Steering Column Lock Failure
#14 Re: коды ошибок, расшифровка
D 1.6 TCI-U2 > Steering > Power Steering
C1103 Ignition Voltage Fault
C1109 IGN Signal Error
C1290 Torque sensor main signal fail
C1603 Derating (EPS Thermal Protection)
C1616 CAN Bus Off
C1617 EMS Invalid Engine Speed
C1692 CAN Time-out VSM
C1700 Byte Coding Error
C1704 ECU Fail-Safe Relay Fail
C1705 ECU Precharge Circuit Fault
C2101 Motor relay circuit
C2400 Motor Fault - Motor Not Running
C2401 Motor circuit
C2412 Motor Short or Open
C2413 Motor current fail (current over)
#15 Re: коды ошибок, расшифровка
D 1.6 TCI-U2 > Tire Pressure Monitoring > Tire Pressure Monitoring
C1300 TPMS ECU IRX not responding
C1332 Front Left Sensor Fault
C1334 Left Rear Sensor Fault
C1335 Rear Right Sensor Fault
C1337 Left Front Low Frequency Initiator Fail Pulse Detected
C1338 Right Front Low Frequency Initiator Fail Pulse Detected
C1339 Right Rear Low Frequency Initiator Fail Pulse Detected
C1341 Left Front Low Frequency Initiator Channel Failure
C1342 Right Front Low Frequency Initiator Channel Failure
C1343 Left REAR Low Frequency Initiator Channel Failure
C1344 Right Rear Low Frequency Initiator Channel Failure
C1351 Left Front Low Frequency Initiator Open/Short Failure
C1352 Right Front Low Frequency InitiatorI Open/Short Failure
C1353 Right Rear Low Frequency Initiator Open/Short Failure
C1616 CAN Bus Off
C1661 Receiver EEPROM Failure
C1662 Auto Learning failure
#16 Re: коды ошибок, расшифровка
Отправлено 18 February 2021 - 18:55
D 1.6 TCI-U2 > Engine > Engine Control(CPF+)
P0047 VGT Vaccum Modulator- Circuit Low
P0048 VGT Vaccum Modulator- Circuit High
P0069 Boost Press. Sensor - Malfunction
P0097 Intake Air Temperature Sensor - Circuit Low Input
P0098 Intake Air Temperature Sensor - Circuit High Input
P0101 Mass or Volume Air Flow Circuit Range/Performance
P0103 Mass or Volume Air Flow Circuit High Input
P0107 Boost Press. Sensor Circuit-Low Input
P0108 Boost Press. Sensor Circuit-High Input
P0122 Throttle Actuator Position Sensor Circuit Low Input
P0123 Throttle Actuator Position Sensor Circuit High Input
P0192 Fuel Rail Press. Sensor-Low Input
P0193 Fuel Rail Press. Sensor-High Input
P0194 Fuel Rail Pressure Sensor "A" Circuit Intermittent/Erratic
P0234 Turbocharger/Supercharger Overboost Condition
P0237 Boost Press. Sensor - Circuit Low Input
P0238 Boost Press. Sensor - Circuit High Input
P0252 Fuel Press. Regulator(MPROP) - Circuit Over Current
P0253 Fuel Press. Regulator(MPROP) - Circuit Low
P0254 Fuel Press. Regulator(MPROP) - Circuit High
P0299 Turbocharger/Supercharger Underboost
P0340 Camshaft Position Sensor A Circuit Malfunction (Bank 1 or Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or Single Sensor)
P0381 Glow Indicator Lamp - Circuit Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0404 Exhaust Gas Recirculation Control Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low(R Engine)
P0406 Exhaust Gas Recirculation Sensor A Circuit High(R Engine)
P0471 Exhaust Pressure Sensor "A" Circuit Range/Performance
P0472 CPF Differential Pressure Sensor "A" Circuit Low Input
P0473 CPF Differential Pressure Sensor "A" Circuit High Input
P0489 Exhaust Gas Recirculation Control Circuit Low Voltage
P0490 Exhaust Gas Recirculation Control Circuit High Voltage
P0546 Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 1)
P0557 Brake Booster Pressure Sensor Circuit Low
P0558 Brake Booster Pressure Sensor Circuit High
P0562 System Voltage Low
P0563 System Voltage High
P0602 EEPROM-Programing Error
P0606 ECM/PCM Processor(ECM-SELF TEST Failed)
P0617 Starter Cut Relay Circuit High
P0620 Generator Control Circuit
P062D Voltage Regulator #1 for Injector - Malfunction
P062E Voltage Regulator #2 for Injector - Malfunction
P0643 Sensor Reference Voltage A Circuit High
P0653 Sensor Reference Voltage B Circuit High
P0670 Glow Relay - Circuit Malfunction
P0699 Sensor Reference Voltage "C" Circuit High
P0820 Neutral S/W Malfunction
P0830 Clutch S/W Malfunction
P1185 Fuel Pressure Monitoring-Maximum Pressure Exceeded
P1186 Fuel Pressure Monitoring-Minimum Pressure at Engine Speed Too Low
P12BF ECU Torque Monitoring - Not Plausible Signal
P1302 ECU Torque Monitoring - ADC Error
P1586 MT/AT Encoding
P1587 CAN Communication Error (MT/AT Recognition Error)
P1588 Signal Change through MT/AT Line (During Engine Running)
P1595 Not plausible ISG auto recognition
P1670 Injector Classification Error
P1815 ESP Auto Recognition Error
P2002 Diesel Particulate Filter Efficiency Below Threshold
P2009 Variable Swirl Actuator Motor - Circuit Low
P2010 Variable Swirl Actuator Motor - Circuit High
P2015 Variable Swirl Actuator Motor - Malfunction
P2016 Variable Swirl Actuator Position Sensor - Circuit Low Input
P2017 Variable Swirl Actuator Position Sensor - Circuit High Input
P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 / Sensor 2)
P2101 Throttle actuator Motor Circuit Range/Performance
P2102 Throttle Actuator Motor Circuit Low
P2103 Throttle Actuator Motor Circuit High
P2107 Throttle Actuator Control System - Over Current Error
P2111 Throttle Actuator Control System - Stuck Open
P2112 Throttle Actuator Control System - Stuck Closed
P2127 Acceleration Position Sensor 2 Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch E Circuit High Input
P2238 HO2S Pumping Current Circuit Low-Bank 1, Sensor 1
P2239 HO2S Pumping Current Circuit High-Bank 1, Sensor 1
P2251 HO2S Reference Ground Circuit/Open-Bank 1 Sensor 1
P2264 Detection of Water in Fuel
P2299 Brake Switch and Accel Pedal Sensor Signals Input Simultaneously at Times
P242F Diesel Particulate Filter Restriction - Ash Accumulation
P2454 CPF differential Pressure Sensor "A" Low Input
P2455 CPF Differential Pressure Sensor "A" High Input
P2501 Generator Lamp/L-Terminal Circuit High
P2502 Charging System Voltage
P2503 Charging System Voltage Low
P2504 Charging System Voltage High
U0001 CAN Communication Malfunction
U0101 ECM-TCM CAN Error
U0155 Vehicle Communication Bus A
U0164 Lost Communication with HVAC Control Module
U1112 LIN Communication Error
#17 Re: коды ошибок, расшифровка
D 1.4 TCI-U2 > Air Conditioner > Air Conditioner
B1202 Heater/Engine-Coolant Water Temperature Sensor Open(High)
B1203 Heater/Engine-Coolant Water Temperature Sensor Short(Low)
B1237 Ambient Temperature Sensor Short (Low)
B1238 Ambient Temperature Sensor Open (High)
B1245 Air Mix Potentiometer Open (Low)-Driver
B1246 Air Mix Potentiometer Short (High)-Driver
B1249 Direction Potentiometer Open (Low)-Driver
B1250 Direction Potentiometer Short (High)-Driver
B1286 Duct sensor short (Low) - Vent
B1287 Duct sensor open (High) - Vent
B1288 Duct sensor short (Low) - Floor
B1289 Duct sensor open (High) - Floor
B1686 Vehicle Speed Sensor Fault – CAN Signal
B1687 Engine Coolant Temperature Sensor Circuit - CAN Signal
B2406 Air Mix Motor-Driver
B2408 Intake Motor
B2409 Direction Control Motor-Driver
#18 Re: коды ошибок, расшифровка
D 1.4 TCI-U2 > Airbag > Airbag Control(Event #1)
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1328 FIS(Front Impact Sensor)-Driver Defect
B1329 FIS(Front Impact Sensor)-Driver Communication error
B1330 FIS(Front Impact Sensor)-Driver Wrong ID
B1333 FIS(Front Impact Sensor)-Passenger Defect
B1334 FIS(Front Impact Sensor)-Passenger Communication error
B1335 FIS(Front Impact Sensor)-Passenger Wrong ID
B1342 Passive Sensors Cross Coupling
B1348 Driver Airbag resistance circuit short to Ground (1st stage)
B1349 Driver Airbag resistance circuit short to Battery (1st stage)
B1383 Side Airbag Front-Passenger Resistance too Low
B1395 Firing Loops Interconnection Fault
B1400 SIS(Side Impact Sensor) Front-Driver defect
B1403 SIS(Side Impact Sensor)Front-Passenger Defect
B1409 SIS(Side Impact Sensor) Front-Driver Communication Error
B1410 SIS(Side Impact Sensor) Front-Passenger Communication Error
B1414 SIS(Side Impact Sensor) Front-Driver Wrong ID
B1415 SIS(Side Impact Sensor) Front-Passenger Wrong ID
B1473 Inflatable Curtain Airbag Front-Driver Resistance too High
B1474 Inflatable Curtain Airbag Front-Driver Resistance too Low
B1475 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Ground
B1476 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Battery
B1477 Inflatable Curtain Airbag Front-Passenger Resistance too High
B1478 Inflatable Curtain Airbag Front-Passenger Resistance too Low
B1479 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Ground
B1480 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Battery
B1527 Passenger airbag On/Off switch open or short to Battery
B1528 Passenger airbag On/Off switch short or short to Ground
B1529 Passenger airbag On/Off switch defect
B1620 Internal fault-Replace SRSCM
B1650 Crash Recorded in 1st Stage Only(Frontal-Replace SRSCM)
B1651 Crash Recorded in Front-Driver Side Airbag(Replace SRSCM)
B1652 Crash Recorded in Front-Passenger Side Airbag(Replace SRSCM)
B1655 Crash recorded (Side - Replace SRSCM)
B1683 Exceed Maximum Coding Number
B1684 ACU Configuration is different
B1762 ACU Coding Error
B2500 Warning lamp Failure
B2505 Passenger Airbag off Warning Lamp Failure
#19 Re: коды ошибок, расшифровка
D 1.4 TCI-U2 > Brake > ABS/ESP
C1520 Clutch switch
C1616 CAN Bus Off
#20 Re: коды ошибок, расшифровка
D 1.4 TCI-U2 > Immobilizer > Immobilizer
Последние обсуждения по Киа Венга YN на MyKia.club
Киа Венга YN
Другие модели Киа →
Киа Венга клуб →
Электрика и Аудио Kia Venga →
электроразъемы (коннекторы)Автор krionika, 05 Dec 2022 |
Киа Венга YN
Другие модели Киа →
Киа Венга клуб →
Двигатель и КПП Kia Venga →
бензобакАвтор krionika, 01 Jun 2010 |
Киа Венга YN
Другие модели Киа →
Киа Венга клуб →
радиатор охлажденияАвтор krionika, 31 May 2010 |
Киа Венга YN
Другие модели Киа →
Киа Венга клуб →
Прочие вопросы по Kia Venga →
инструкция по эксплуатацииАвтор krionika, 03 Jul 2010 |
Киа Венга YN
Другие модели Киа →
Киа Венга клуб →
подрулевой переключательАвтор krionika, 06 Feb 2022 |
