Киа Венга YN
Сообщений в теме: 32
  • 24971 сообщений
Отправлено 18 February 2021 - 18:53
Коды ошибок Kia Venga (YN)
G 1.4 DOHC > Air Conditioner > Air Conditioner
B1202 Heater/Engine-Coolant Water Temperature Sensor Open(High)
B1203 Heater/Engine-Coolant Water Temperature Sensor Short(Low)
B1237 Ambient Temperature Sensor Short (Low)
B1238 Ambient Temperature Sensor Open (High)
B1245 Air Mix Potentiometer Open (Low)-Driver
B1246 Air Mix Potentiometer Short (High)-Driver
B1249 Direction Potentiometer Open (Low)-Driver
B1250 Direction Potentiometer Short (High)-Driver
B1286 Duct sensor short (Low) - Vent
B1287 Duct sensor open (High) - Vent
B1288 Duct sensor short (Low) - Floor
B1289 Duct sensor open (High) - Floor
B1686 Vehicle Speed Sensor Fault – CAN Signal
B1687 Engine Coolant Temperature Sensor Circuit - CAN Signal
B2406 Air Mix Motor-Driver
B2408 Intake Motor
B2409 Direction Control Motor-Driver
  • 24971 сообщений
G 1.4 DOHC > Airbag > Airbag Control(Event #1)
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1328 FIS(Front Impact Sensor)-Driver Defect
B1329 FIS(Front Impact Sensor)-Driver Communication error
B1330 FIS(Front Impact Sensor)-Driver Wrong ID
B1333 FIS(Front Impact Sensor)-Passenger Defect
B1334 FIS(Front Impact Sensor)-Passenger Communication error
B1335 FIS(Front Impact Sensor)-Passenger Wrong ID
B1342 Passive Sensors Cross Coupling
B1348 Driver Airbag resistance circuit short to Ground (1st stage)
B1349 Driver Airbag resistance circuit short to Battery (1st stage)
B1383 Side Airbag Front-Passenger Resistance too Low
B1395 Firing Loops Interconnection Fault
B1400 SIS(Side Impact Sensor) Front-Driver defect
B1403 SIS(Side Impact Sensor)Front-Passenger Defect
B1409 SIS(Side Impact Sensor) Front-Driver Communication Error
B1410 SIS(Side Impact Sensor) Front-Passenger Communication Error
B1414 SIS(Side Impact Sensor) Front-Driver Wrong ID
B1415 SIS(Side Impact Sensor) Front-Passenger Wrong ID
B1473 Inflatable Curtain Airbag Front-Driver Resistance too High
B1474 Inflatable Curtain Airbag Front-Driver Resistance too Low
B1475 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Ground
B1476 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Battery
B1477 Inflatable Curtain Airbag Front-Passenger Resistance too High
B1478 Inflatable Curtain Airbag Front-Passenger Resistance too Low
B1479 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Ground
B1480 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Battery
B1527 Passenger airbag On/Off switch open or short to Battery
B1528 Passenger airbag On/Off switch short or short to Ground
B1529 Passenger airbag On/Off switch defect
B1620 Internal fault-Replace SRSCM
B1650 Crash Recorded in 1st Stage Only(Frontal-Replace SRSCM)
B1651 Crash Recorded in Front-Driver Side Airbag(Replace SRSCM)
B1652 Crash Recorded in Front-Passenger Side Airbag(Replace SRSCM)
B1655 Crash recorded (Side - Replace SRSCM)
B1683 Exceed Maximum Coding Number
B1684 ACU Configuration is different
B1762 ACU Coding Error
B2500 Warning lamp Failure
B2505 Passenger Airbag off Warning Lamp Failure
  • 24971 сообщений
G 1.4 DOHC > Brake > ABS/ESP
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1213 Wheel Speed Frequency Error
C1285 Sensor Cluster Change Detection/Uncalibrated
C1520 Clutch switch
C1527 Gear R Switch Error
C1604 ECU Hardware Error
C1605 CAN Hardware Error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1613 CAN Wrong Message
C1616 CAN Bus Off
C1626 Implausible Control
C1643 CAN Time-out Yaw Rate & Lateral G Sensor
C1702 Variant Coding Error
C2112 Valve Relay Error
C2308 Front-LH Valve error (Inlet Valve)
C2312 Front-LH Valve error (Outlet Valve)
C2316 Front-RH Valve error (Inlet Valve)
C2320 Front-RH Valve error (Outlet Valve)
C2324 Rear-LH Valve error (Inlet Valve)
C2328 Rear-LH Valve error (Outlet Valve)
C2332 Rear-RH Valve error (Inlet Valve)
C2336 Rear-RH Valve error (Outlet Valve)
C2366 TC Valve Primary (USV1) Error
C2370 TC Valve Secondary (USV2) Error
C2372 Electronic Shuttle Valve Primary (HSV1) Error
C2374 Electronic Shuttle Valve Secondary (HSV2) Error
C2402 Motor Electrical
  • 24971 сообщений
G 1.4 DOHC > Immobilizer > Immobilizer
P1675 Immobilizer-Transponder Programming Error
P169A Immobilizer-SMARTRA Authentication Fail
P1692 Immobilizer Indicator Lamp Error
G 1.4 DOHC > Power Distribution Module > Power Distribution Module
B1602 CAN Error
B1603 CAN Bus Off
B1987 Sub Micom Failed
B1988 ESCL Battery Short Circuit To Battery
B1989 ESCL Ground Short Circuit To Battery
B1990 ESCL Battery Short Circuit To Ground
B1991 Immobilizer TX Short Circuit To Ground
  • 24971 сообщений
G 1.4 DOHC > Smart Key > Smart Key Code Saving
G 1.4 DOHC > Smart Key > Smart Key Unit
B1602 CAN Error
B1603 CAN Bus Off
B1604 CAN Timeout between SMK and (IPM or BCM)
B1625 ECM Communication Data Failure
B1689 CAN Time-out PDM
B1971 Parking Position Input Error
B1978 Electric Steering Column Lock Failure
  • 24971 сообщений
G 1.4 DOHC > Steering > Power Steering
C1103 Ignition Voltage Fault
C1109 IGN Signal Error
C1290 Torque sensor main signal fail
C1603 Derating (EPS Thermal Protection)
C1616 CAN Bus Off
C1617 EMS Invalid Engine Speed
C1692 CAN Time-out VSM
C1700 Byte Coding Error
C1704 ECU Fail-Safe Relay Fail
C1705 ECU Precharge Circuit Fault
C2101 Motor relay circuit
C2400 Motor Fault - Motor Not Running
C2401 Motor circuit
C2412 Motor Short or Open
C2413 Motor current fail (current over)
  • 24971 сообщений
G 1.4 DOHC > Tire Pressure Monitoring > Tire Pressure Monitoring
C1300 TPMS ECU IRX not responding
C1332 Front Left Sensor Fault
C1334 Left Rear Sensor Fault
C1335 Rear Right Sensor Fault
C1337 Left Front Low Frequency Initiator Fail Pulse Detected
C1338 Right Front Low Frequency Initiator Fail Pulse Detected
C1339 Right Rear Low Frequency Initiator Fail Pulse Detected
C1341 Left Front Low Frequency Initiator Channel Failure
C1342 Right Front Low Frequency Initiator Channel Failure
C1343 Left REAR Low Frequency Initiator Channel Failure
C1344 Right Rear Low Frequency Initiator Channel Failure
C1351 Left Front Low Frequency Initiator Open/Short Failure
C1352 Right Front Low Frequency InitiatorI Open/Short Failure
C1353 Right Rear Low Frequency Initiator Open/Short Failure
C1616 CAN Bus Off
C1661 Receiver EEPROM Failure
C1662 Auto Learning failure
  • 24971 сообщений
Отправлено 18 February 2021 - 18:54
G 1.4 DOHC > Engine > Engine Control
P0011 "A" Camshaft Position-Timing Over-Advanced or System Performance (Bank 1)
P0016 Crankshaft Position–Camshaft Position Correlation (Bank 1 Sensor A)
P0030 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 / Sensor 1)
P0036 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 / Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 / Sensor 2)
P0076 Intake Valve Control Solenoid Circuit-Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit-High (Bank 1)
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0122 Throttle Position Sensor 1 Signal Circuit Low Input
P0123 Throttle Position Sensor 1 Signal Circuit High Input
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0261 Cylinder 1 Injector Circuit Low
P0264 Cylinder 2 Injector Circuit Low
P0267 Cylinder 3 Injector Circuit Low
P0270 Cylinder 4 Injector Circuit Low
P0301 Cylinder 1-Misfire detected
P0302 Cylinder 2-Misfire detected
P0303 Cylinder 3-Misfire detected
P0304 Cylinder 4-Misfire detected
P0340 Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
P0444 Evaporative Emission System-Purge Control Valve Circuit Open
P0445 Evaporative Emission System-Purge Control Valve Circuit Shorted
P0504 Brake Switch “A”/”B” Correlation
P0557 Brake Booster Pressure Sensor Circuit Low
P0558 Brake Booster Pressure Sensor Circuit High
P0560 System Voltage
P0562 System Voltage Low
P0563 System Voltage High
P0616 Starter Relay Circuit Low
P0617 Starter Relay Circuit High
P0620 Alternator Control Circuit
P0625 Generator Field/ F Terminal Circuit Low
P0626 Generator Field/F Terminal Circuit High
P0638 Throttle Actuator Control Range / Performance
P0642 Sensor Reference Voltage "A" Circuit Low
P0643 Sensor Reference Voltage "A" Circuit High
P0704 Clutch Switch Input Circuit Malfunction
P0820 Gear Lever X-Y Position Sensor Circuit
P2096 Post Catalyst Fuel Trim System too Lean (Bank 1)
P2097 Post Catalyst Fuel Trim System too Rich (Bank 1)
P2101 Throttle Actuator Control Motor Circuit Range/Performance
P2104 Limp Home Mode - Forced Idle
P2105 Limp Home Mode - Force Engine Shutdown
P2106 Lime Home Mode - Force Limited Power
P2110 Throttle Actuator Control System-Force Limited RPM
P2118 Throttle Actuator Control Motor Current Range/Performance
P2119 Throttle Actuator Control Throttle Body Range/Performance
P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low Input
P2123 Throttle/Pedal Position Sensor /Switch "D" Circuit High Input
P2127 Throttle/Pedal Position Sensor/Switch "E" Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch "E" Circuit High Input
P2159 Vehicle Speed Sensor "B" Range / Performance(Wheel Speed Sensor)
P2187 System too Lean at Idle (←Additive) (Bank 1)
P2188 System too Rich at Idle (Bank 1)
P2191 System too Lean at Higher Load (Multiple) (Bank 1)
P2192 System too Rich at Higher Load(Bank 1)
U0101 Lost Communication With TCM
U0155 Vehicle Communication Bus A
U0164 CAN Communication BUS with FATC(Timeout)
U1111 Battery Sensor fault detected by ECU
U1112 LIN Communication Error
  • 24971 сообщений
D 1.6 TCI-U2 > Air Conditioner > Air Conditioner
B2408 Intake Motor
  • 24971 сообщений
D 1.6 TCI-U2 > Airbag > Airbag Control(Event #1)
Ещё обсуждения по Киа Венга YN на MyKia.club:
