D 2.5 TCI-A2 > Engine > Engine Control
P0046 Turbocharger/Supercharger Boost Control Solenoid "A" Circuit Range/Performance
P0047 Turbocharger/Supercharger Boost Control Solenoid "A" Circuit Low
P0048 Turbocharger/Supercharger Boost Control Solenoid "A" Circuit High
P0069 Manifold Absolute Pressure – Barometric Pressure Correlation
P0097 Intake Air Temperature Sensor 2 Circuit Low Input
P0098 Intake Air Temperature Sensor 2 Circuit High Input
P0101 Mass or Volume Air Flow "A" Circuit Range / Performance
P0102 Mass or Volume Air Flow "A" Circuit Low Input
P0103 Mass or Volume Air Flow "A" Circuit High Input
P0122 Throttle Position Sensor 1 Signal Circuit Low Input
P0123 Throttle Position Sensor 1 Signal Circuit High Input
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0191 Fuel Rail Pressure Sensor "A" Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor "A" Circuit Low
P0193 Fuel Rail Pressure Sensor "A" Circuit High
P0237 Turbocharger/Supercharger Boost Sensor "A" Circuit Low
P0238 Turbocharger/Supercharger Boost Sensor "A" Circuit High
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0263 Cylinder 1 Contribution/Balance
P0266 Cylinder 2 Contribution/Balance
P0269 Cylinder 3 Contribution/Balance
P0272 Cylinder 4 Contribution/Balance
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1)
P0381 Glow Plug/Heater Indicator Circuit
P0404 Exhaust Gas Recirculation Control Circuit Range/Performance
P0406 Exhaust Gas Recirculation Sensor A Circuit High(R Engine)
P0472 CPF Differential Pressure Sensor "A" Circuit Low Input
P0473 CPF/DPF Differential Pressure Sensor "A" Circuit High Input
P0489 Exhaust Gas Recirculation Control Circuit Low
P0490 Exhaust Gas Recirculation Control Circuit High
P0501 Vehicle Speed Sensor "A" Range/Performance
P0504 Brake Switch "A" / "B" Correlation
P0532 A/C Refrigerant Pressure Sensor "A" Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor "A" Circuit High Input
P0545 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 1)
P0546 Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 1)
P0562 System Voltage Low
P0563 System Voltage High
P0606 ECM/PCM Processor
P0620 Generator Control Circuit
P062D Fuel Injector Driver Circuit Performance (Bank 1)
P062E Fuel Injector Driver Circuit Performance (Bank 2)
P0643 Sensor Reference Voltage "A" Circuit High
P0670 Glow Plug Control Module Control Circuit / Open
P0830 Clutch Pedal Switch "A" Circuit
P1119 Inlet Metering Valve Control Malfunction
P1120 Inlet Metering Valve Circuit Malfunction
P12BF ECU Torque Monitoring - Not Plausible Signal
P1405 CPF-Permanent Regeneration
P1407 Plausibility Of Temperature Calculated And Simulated Upstream Of Particulate Filter
P1634 Auxiliary Heater Relay short/open circuit
P1670 Invalid Injector IQA/C2I
P1675 Transponder Programming Error
P2002 Diesel Particulate Filter Efficiency Below Threshold(Bank1)
P2032 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 / Sensor 2)
P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 / Sensor 2)
P2102 Throttle Actuator Control Motor Circuit Low
P2103 Throttle Actuator Control Motor Circuit High
P2113 Throttle Actuator Control System - Feedback signal Failed
P2122 Accelerator Position Sensor 1 Signal Circuit Low Input
P2123 Throttle/Pedal Position Sensor /Switch "D" Circuit High Input
P2127 Accelerator Position Sensor 2 Signal Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch "E" Circuit-High Input
P2228 Barometric Pressure Circuit Low Input
P2229 Barometric Pressure Circuit High Input
P2264 Water in Fuel Sensor Circuit
P242F Diesel Particulate Filter Restriction - Ash Accumulation
P2501 Generator Lamp/L-Terminal Circuit High
P2502 Charging System Voltage
P2503 Charging System Voltage Low
P250F Engine Oil Level Too Low
U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module (C-CAN)
U0164 Lost Communication with HVAC Control Module
U1111 Battery Sensor fault detected by ECU
U1112 LIN Communication Error
#11
Отправлено 16 February 2021 - 17:26
Re: коды ошибок, расшифровка
Отправлено 16 February 2021 - 17:27
D 2.9 C/R-J > Engine > Engine Control
P0016 Crankshaft Position–Camshaft Position Correlation (Bank 1 Sensor A)
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0194 Fuel Rail Pressure Sensor "A" Circuit Intermittent/Erratic
P0330 Knock Sensor 2 Circuit (Bank 2)
P0340 Camshaft Position Sensor "A" Circuit (Single Sensor)
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0607 Control Module Performance
P0642 Sensor Reference Voltage "A" Circuit Low
P1588 MT/AT AUTO RECOGNITION LINE ERROR
P1630 InterCooler Fan Relay Short/Open Circuit
P1655 Tacho Output Fault
P2122 Throttle/Pedal Position Sensor/Switch "D" Circuit Low Input
P2127 Throttle/Pedal Position Sensor/Switch "E" Circuit Low Input
P2147 Fuel Injector Group "A" Supply Voltage Circuit Low
P2148 Fuel Injector Group "A" Supply Voltage Circuit High
P2299 Brake Pedal Position / Accelerator Pedal Position Incompatible
Ещё обсуждения по Киа Бонго PU на MyKia.club:
Киа Бонго PU
Другие модели Киа →
Киа Бонго клуб →
ручникАвтор krionika, 14 Jul 2008 |
Киа Бонго PU
Другие модели Киа →
Киа Бонго клуб →
подкрылкиАвтор Михаил34, 18 Jan 2021 |
Киа Бонго PU
Другие модели Киа →
Киа Бонго клуб →
передняя (приборная) панельАвтор krionika, 10 Dec 2015 |
Киа Бонго PU
Другие модели Киа →
Киа Бонго клуб →
обтекатель на крышуАвтор krionika, 03 Dec 2014 |
Киа Бонго PU
Другие модели Киа →
Киа Бонго клуб →
амортизаторы и пружиныАвтор krionika, 06 Oct 2014 |
