передняя (приборная) панель
Сообщений в теме: 18
  • 18512 сообщений
Отправлено 10 November 2015 - 13:11
киа пиканто 1 (SA) СНЯТИЕ И УСТАНОВКА
REPLACEMENT CLUSTER FASCIA REPLACEMENT • When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage. • Put on gloves to protect your hands. 1. Tilt the steering column down. 2. After loosening the mounting screws, remove the cluster fascia panel (A). Untitled-1 copy.jpg
:excl: Клубный автосервис Киа Хендай в Москве :excl:
#2 krionika Re: передняя (приборная) панель
  • 18512 сообщений
Отправлено 10 November 2015 - 13:12
3. After loosening the mounting screws, then remove the cluster fascia (B). Untitled-1 copy.jpg
#3 krionika Re: передняя (приборная) панель
  • 18512 сообщений
Отправлено 10 November 2015 - 13:13
4. Installation is the reverse the removal. • Make sure the connector is plugged in properly. CENTER FASCIA PANEL REPLACEMENT • When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage. • Put on gloves to protect your hands. 1. Put the SST (09840-1E100) (A) into the space between the center fascia and crash pad. • Be care not to damage the center fascia and crash pad. Untitled-1 copy.jpg
#4 krionika Re: передняя (приборная) панель
  • 18512 сообщений
2. Separate the center fascia panel (B) from the crash pad pulling the SST (09840-1E100) as shown on the photo. • Pull the SST slowly not to damage the center fascia panel. Untitled-1 copy.jpg
#5 krionika Re: передняя (приборная) панель
  • 18512 сообщений
Отправлено 10 November 2015 - 13:14
3. Pull the other side of center fascia panel with the SST in the way of "step 2)". 4. Disconnect the connector ©. Untitled-1 copy.jpg
#6 krionika Re: передняя (приборная) панель
  • 18512 сообщений
5. Installation is the reverse of removal. LOWER PANEL REPLACEMENT 1. Remove the crash pad side cover. 2. After loosening the crash pad lower panel mounting screws, then remove the lower panel (A). Untitled-1 copy.jpg
#7 krionika Re: передняя (приборная) панель
  • 18512 сообщений
Отправлено 10 November 2015 - 13:15
#8 krionika Re: передняя (приборная) панель
  • 18512 сообщений
Отправлено 10 November 2015 - 13:16
#9 krionika Re: передняя (приборная) панель
  • 18512 сообщений
5. Installation is the reverse of removal. HEATER CONTROL UNIT REPLACEMENT 1. Remove the center fascia panel. 2. Remove the lower fascia panel (A). Untitled-1 copy.jpg
#10 krionika Re: передняя (приборная) панель
  • 18512 сообщений
Отправлено 10 November 2015 - 13:17
Ответить
Последние обсуждения по киа пиканто 1 sa на MyKia.club
Яндекс.Метрика Top.Mail.Ru Запрещено любое копирование материалов сайта без согласия администрации. Copyright © 2022 mykia.club
