Киа Рио 3 QB
сцепление
  • 3844 сообщений
Отправлено 06 November 2012 - 14:59
Kia Rio UB/QB (2011+) - замена сцепления
Removal 1. Remove the transaxle assembly. (Refer to "Manual transaxle system" in MT group) 2. Remove the clutch cover bolts. Be careful not to be bent or twist bolts. Loosen bolts in diagonal directions. Прикрепленный файл  Kia Rio UBQB (2011+) - замена сцепления.jpg   63.02К   7 Количество загрузок:
#2 getAway Re: сцепление
  • 3844 сообщений
Отправлено 06 November 2012 - 15:06
Installation
Replace a clutch cover and disc as a set.
When replacing only a disc, a slip problem can occur because of the load loss due to uneven surface wear.
When replacing only a disc, it can be difficult to cut power because the thickness of the disc won't permit it.
Apply grease on a disc spline part and transaxle input shaft spline part as required.
* Possible problems when not following
When not applying: Excessive wear of splines and bad clutch operation can occur.
When excessively applying: Grease can be scattered by centrifugal force which can contaminate the clutch disc. This can cause a loss of friction force causing a slip.
Прикрепленный файл  Kia Rio UB QB 2011 - замена сцепления (1).jpg   27.41К   8 Количество загрузок:
The 'T/M SIDE' marked surface should face the transaxle.
* Possible problems when the disc is installed in the opposite direction.
There can be an interference between the concentric slave cylinder on the TM side and a engine flywheel surface.
Transaxle shift errror or a strange sound can occur due to clutch separation.
The clutch release bearing can break. If it does, the clutch release bearing should be replaced new one.
Прикрепленный файл  Kia Rio UB QB 2011 - замена сцепления (2).jpg   25.01К   7 Количество загрузок:
4.
Install the clutch disc and the cover with SST(A : 09411-1P000).
Прикрепленный файл  Kia Rio UB QB 2011 - замена сцепления (3).jpg   63.58К   9 Количество загрузок:
5.
Install the clutch cover bolts. Not to be bent or twisted, Tighten them in diagonal directions.
Tightening torque:
14.7 ~ 21.6 N.m (1.5 ~ 2.2 kgf.m, 10.8 ~ 15.9 lb-ft)
Loosely tighten every clutch cover bolts, then torque to specifications in a diagonal direction. This can prevent twisting, vibration of the cover, and the lifting of the pressure plate.
Install the all the components with the specified torques. If not, the clutch torque transaxle may have concerns or the mounting bolt can loosen.
Прикрепленный файл  Kia Rio UB QB 2011 - замена сцепления (4).jpg   54.07К   7 Количество загрузок:
6.
Install the transaxle assembly.
#3 krionika Re: сцепление
  • 24074 сообщений
Отправлено 15 August 2011 - 21:48
[color=#0000ff;]Сцепление 1.4 5мт[/color]
[color=#0000ff;]Прикрепленный файл  Сцепление Киа Рио QB.gif   10.83К   0 Количество загрузок:[/color]
[color=#0000ff;]
[/color]
Последние обсуждения по киа рио 3 qb на MyKia.club
