Киа Рио 1 BC
сцепление
  • 3961 сообщений
Отправлено 03 November 2012 - 16:49
киа рио 1 (BC)
 Kia Rio BC (2000-2006) - замена сцепления
Removal Pressure plate and clutch disc Do not allow oil or grease to contaminate the clutch disc facing. Even a trace of oil or grease may cause clutch grabbing or slipping. Handle the disc by its edges and do not touch the facing. 1. Remove the transaxle. Refer to Section MT. 2. If the pressure plate will be reused, paint or scribe the alignment marks on the pressure plate and flywheel for assembly reference. Loosen the pressure plate bolts one turn at a time to release the pressure plate spring tension evenly. A failure to release the tension evenly could cause distortion of the pressure plate. 3. Remove the pressure plate bolts, the pressure plate, and the clutch disc. While loosening the bolts, use SST to prevent turning of the flywheel. Прикрепленный файл  Kia Rio BC (2000-2006) - замена сцепления.jpg   39.85К   14 Количество загрузок:
#2 getAway Re: сцепление
  • 3961 сообщений
Отправлено 03 November 2012 - 16:51
Installation
Position the clutch disc on the flywheel and hold it in position with SST.
Прикрепленный файл  Kia Rio BC 2000-2006 - замена сцепления (1).jpg   39.57К   11 Количество загрузок:
Use the marks which were made during removal for the alignment reference.
Tighten the bolts evenly and alternately to prevent distortion of the pressure plate.
Tighten tTightening torque : 13~20 lb·ft (18~26 N·m, 1.8~2.7 kg·m)he pressure plate bolts.
Tightening torque :
Прикрепленный файл  Kia Rio BC 2000-2006 - замена сцепления (2).jpg   29.07К   13 Количество загрузок:
4.
Remove the clutch alignment tool.
Before installing the transaxle, clean the clutch disc splines on the input shaft and coat them with a light film of a Clutch Grease, or equivalent.
5.
Install the transaxle.
#3 krionika Re: сцепление
  • 24806 сообщений
Отправлено 14 June 2000 - 12:37
[color=#0000ff;]Сцепление[/color]
Прикрепленный файл  Сцепление Киа Рио BC.gif   8.5К   0 Количество загрузок:
Ещё обсуждения по Киа Рио 1 BC на MyKia.club:
