Киа Карнивал 2 (VQ)
генератор
Сообщений в теме: 5
#1 get away
get away
  • 3240 сообщений
Отправлено 05 October 2012 - 15:55
Kia Carnival VQ (2006-2010) - снятие и установка генератора D 2.9 WGT , D 2.9 VGT
REPLACEMENT 1. Disconnect the battery negative terminal frist, then the positive terminal. 2. Disconnect the alternator connector(A) and "B" terminal cable(B). 1 copy.jpg 3. Remove the oil pipe(B), oil hose© from the vacuum pump(A). 2 copy.jpg 4. Remove the drive belt. 3 copy.jpg 5. Remove the movnting bolts(B.C) and net(D) then remove the alternator(A). 4 copy.jpg 6. Installation is the reverse of removal.
#2 get away Re: генератор
get away
  • 3240 сообщений
Отправлено 05 October 2012 - 15:58
G 3.5 DOHC
Removal and Installation
Disconnect the battery negative cable.
Remove the engine cover.
Disconnect the alternator connector (A) and cable (B) from the 'B' terminal.
4.
To release the tension, turn the drive belt tensioner counterclockwise then remove the drive belt (A).
5.
Remove the alternator (A).
Tightening torque :
26.5 ~ 33.3 N.m (2.7 ~ 3.4 kgf.m, 19.5 ~ 24.6 lb-ft)
6.
Installation is reverse order of removal.
#3 get away Re: генератор
get away
  • 3240 сообщений
Отправлено 05 October 2012 - 16:02
D 2.2 TCI-R
Removal
Disconnect the battery negative terminal (A) first, then the positive terminal (B).
Using the hexagon wrench, turn the tensioner conterclockwise, then remove the drive belt(A).
Disconnect the alternator connector(A), and remove the cable(B) from alternator "B" terminal.
4.
Tightening torque :
49.0 ~ 63.7N.m (5.0 ~ 6.5kgf.m, 36.2 ~ 47.0lb-ft)
5.
Installation is the reverse order of removal.
#4 get away Re: генератор
get away
  • 3240 сообщений
Отправлено 05 October 2012 - 16:03
G 2.7 DOHC
REMOVAL
Disconnect the battery negative terminal first, then the positive terminal.
Disconnect the alternator connector, and remove the cable from alternator "B" terminal.
4.
Pull out the through bolt and then remove the alternator(A).
5.
#5 get away Re: генератор
get away
  • 3240 сообщений
Отправлено 05 October 2012 - 16:05
G 3.8 DOHC
REMOVAL
4.
5.
#6 krionika Re: генератор
  • 18289 сообщений
Отправлено 05 July 2007 - 10:49
1140EJ  БОЛТ М6  1140306126K   1140FJ  БОЛТ М6  1140308307B   37300A  ГЕНЕРАТОР В СБОРЕ  373003E100   37311E  ГАЙКА  373113C110   37321B  ШКИВ ГЕНЕРАТОРА  373213E001   37330E  КОРПУС-ГЕНЕРАТОР  373303E100   37338C  БОЛТ-СКВОЗН.  3733825010   37340E  РОТОР  373403C000   37350B  СТАТОР ГЕНЕРАТОРА  373503E100   37360E  РАМА-ГЕНЕРАТОР  373603E100   37367B  ВЫПРЯМИТЕЛЬ ГЕНЕРАТОРА  373804A300   37368E  ФИКСАТОР ЩЕТОК  3736825110   37370B  ВЫПРЯМИТЕЛЬ ГЕНЕРАТОРА  3737025110   37390B  КРЫШКА  373903C000   37451  БОЛТ М6  3745125000   37460  КРОНШТЕЙН-ГЕНЕРАТОР  374603E000   91980M  КРОНШТЕЙН-ПОДВЕС  919803L150
Ответить
Последние обсуждения по киа карнивал 2 (vq) на MyKia.club
Запрещено любое копирование материалов сайта без согласия администрации. Copyright © 2021 mykia.club
