Киа Каренс 2 UN
сцепление
  • 4013 сообщений
Отправлено 02 November 2012 - 15:02
Kia Carens UN (2006-2011) - замена сцепления Removal 1. Remove the transaxle assembly. (Refer to "Manual transaxle system" in MT group) 2. Remove the clutch cover bolts. Be careful not to be bent ortwist bolts. Loosen bolts in diagonal directions. Прикрепленный файл  Kia Carens UN (2006-2011) - замена сцепления.jpg   63.02К   10 Количество загрузок:
#2 getAway Re: сцепление
  • 4013 сообщений
Отправлено 02 November 2012 - 15:05
Installation
If reinstalling used cover, the cover should be installed with its clutch disc as a set.
Replace a clutch cover and disc as a set.
When replacing only a disc, a slip problem can occur because of the load loss due to uneven surface wear.
When replacing only a disc, it can be difficult to cut power because the thickness of the disc won't permit it.
Apply grease on a disc spline part and transmission input shaft spline part as required.
* Possible problems when not following
When not applying: Excessive wear of splines and bad clutch operation can occur.
When excessively applying: Grease can be scattered bycentrifugal force which can conteminate the clutch disc. This can cause a loss of friction force causing a slip.
Прикрепленный файл  Kia Carens UN 2006-2011 - замена сцепления (1).jpg   27.41К   8 Количество загрузок:
The 'T/M SIDE' marked surface should face the engineer.
Прикрепленный файл  Kia Carens UN 2006-2011 - замена сцепления (2).jpg   25.01К   9 Количество загрузок:
4.
Install the clutch disc and the cover with SST(A : 09411-1P000).
Прикрепленный файл  Kia Carens UN 2006-2011 - замена сцепления (3).jpg   63.58К   8 Количество загрузок:
5.
Install the clutch cover bolts. Not to be bent or twisted, Tighten them in diagonal directions.
Tightening torque:
24.5 ~ 35.3 N.m (2.5 ~ 3.6 kgf.m, 18.1 ~ 26.0 lb-ft)
Loosely tighten every clutch cover bolts, then torque to specifications in a diagonal direction. This can prevent twisting, vibration of the cover, and the lifting of the pressure plate.
Install the all the components with the specified torques. If not, the clutch torque transmission may have concerns or the mounting bolt can loosen.
Прикрепленный файл  Kia Carens UN 2006-2011 - замена сцепления (4).jpg   54.07К   8 Количество загрузок:
6.
Install the transaxle assembly.( Refer to "Manual transaxle system" in MT group.)
7.
Perform the bleeding air procedure in the clutch release cylinder.
#3 krionika Re: сцепление
Отправлено 14 March 2007 - 16:17
Сцепление Киа Каренс 1,6 5МТ UN
Прикрепленный файл  Сцепление Киа Каренс 1,6 5МТ UN.gif   15.4К   0 Количество загрузок:
1123GT  БОЛТ М6  1123308161   1140KB  БОЛТ-ФЛАНЕЦ  1140506141   1339GA  ГАЙКА  1339608007K   41100  ДИСК СЦЕПЛЕНИЯ В СБОРЕ  MULTI   41300  КОЖУХ  MULTI   41417  ПЫЛЬНИК ВИЛКИ СЦЕПЛЕНИЯ  4141722652   41421B  ПОДШИПНИК ВЫЖИМНОЙ  MULTI   41430B  ОСЬ ВИЛКИ СЦЕПЛЕНИЯ  4143023200   41460B  ТРУБКА СЦЕПЛЕНИЯ  MULTI   41465  КРОНШТЕЙН МАСЛЯНОЙ ТРУБКИ  4146532100   41466  ИЗОЛЯТОР КРОНШТЕЙНА МАСЛЯНОЙ ТРУБКИ  4146634000   41467  ПРОКЛАДКА  4146734000   41471  ОПОРА РЫЧАГА ВЫКЛ. СЦЕПЛЕНИЯ  MULTI   41471C  ШПИЛЬКА  4147123336   41710B  РАБОЧИЙ ЦИЛИНДР СЦЕПЛЕНИЯ  4171023000
Ещё обсуждения по киа каренс 2 un на MyKia.club:
