Kia Sportage AL (1993-2005) - снятие и установка генератора
REMOVAL
1.
Remove negative battery cable.
2.
Remove front bolts from air cleaner inlet pipe.
3.
Loosen end clamp on inlet.
4.
Remove top hose from resonance chamber and remove air cleaner inlet pipe.
5.
Open B-terminal cover cap.
6.
Remove B-terminal nut.
7.
Remove B-terminal lead.
1 copy.jpg 29.5К
17 Количество загрузок:
8.
Disconnect the generator's L- and S-terminal connectors.
9.
Loosen pivot bolt and tensioner mounting bolt. Do not remove.
2 copy.jpg 47.9К
16 Количество загрузок:
10.
Relieve tension on drive belt by rotating adjustment bolt.
11.
Remove drive belt from generator pulley.
12.
Remove tensioner mounting bolt and belt tensioner.
13.
Remove generator pivot bolt.
14.
Loosen bolt at base of adjusting bracket and rotate the bracket up.
15.
Lift generator from engine compartment.
#1
Отправлено 19 September 2012 - 16:06
#2
Re: генератор
Отправлено 19 September 2012 - 16:07
INSTALLATION
1.
Position generator on engine.
2.
Install, but leave loose, pivot bolt.
3.
Rotate bracket down into position on top of generator.
4.
Place belt tensioner into position on adjustment bracket.
5.
Install tensioner mounting bolt, leave loose.
6.
Place drive belt on generator pulley.
7.
Adjust belt tension by rotating adjustment bolt.
Allow deflectiom :
New belt : 0.23-0.31in (6-8mm)
Old belt : 0.28-0.35in (7-9mm)
1 copy.jpg 30.9К
13 Количество загрузок:
8.
Tighten tensioner bolt.
Tighten tensioner bolt to 14-19lb·ft (19-26N·m).
9.
Tighten pivot bolt and bracket bolt.
Tighten pivolt bolt to 28-38lb·ft (38-51N·m).
10.
Connect generator L- and S-terminal connectors.
11.
Connect B-terminal lead.
12.
Install and tighten B-terminal nut.
13.
Close B-terminal nut cover.
14.
Install air intake inlet pipe and tighten end clamp.
15.
Connect top hose to resonance chamber.
16.
Install front air intake inlet pipe bolts.
17.
Connect negative battery cable.
Be sure the battery connections are not reversed. This will damage the rectifier.
Do not use high voltage testers, such as a megger. They will damage the rectifier.
Remember that battery voltage is always applied to the alternator B-terminal.
Do not ground the L-terminal while the engine is running.
Do not start the engine while the coupler is disconnected from the L- and S-terminals.
#3
Re: генератор
Отправлено 12 November 2007 - 09:00
Генератор Киа Спортейдж AL бензин
Генератор Киа Спортейдж AL.gif 14.24К
0 Количество загрузок:
#4
Re: генератор
Отправлено 10 January 2015 - 20:40
Генератор дает зарядку при оборотах 2300-2400, если ниже обороты, то нет. Не горит контрольная лампа зарядки на щитке. При включении зажигания не горит символ аккумулятора. Измерял тестером.
Спортаж какой? Что с натяжением ремнем генератора?
Re: генератор
Отправлено 11 January 2015 - 11:52
тогда скорее всего замена генератора, вышел из строя диодный мост
Ещё обсуждения по киа спортейдж 1 al на MyKia.club:
Киа Спортейдж 1 AL
Киа Спортейдж клуб →
Двигатель и КПП Kia Sportage →
замена АКППАвтор krionika , 08 Feb 2007 |
Киа Спортейдж 1 AL
Электрика и Аудио Kia Sportage →
передние фарыАвтор krionika , 26 Mar 2007 |
Киа Спортейдж 1 AL
воздушный фильтр двигателяАвтор krionika , 14 Jun 2000 |
Киа Спортейдж 1 AL
стартерАвтор krionika , 12 Nov 2007 |
Киа Спортейдж 1 AL
Ходовая, тормоза, шины, диски Kia Sportage →
амортизаторы и пружиныАвтор krionika , 18 Jun 1999 |
