Киа Спортейдж 1 AL
генератор
Сообщений в теме: 6
  • 4010 сообщений
Отправлено 19 September 2012 - 16:06
Kia Sportage AL (1993-2005) - снятие и установка генератора REMOVAL 1. Remove negative battery cable. 2. Remove front bolts from air cleaner inlet pipe. 3. Loosen end clamp on inlet. 4. Remove top hose from resonance chamber and remove air cleaner inlet pipe. 5. Open B-terminal cover cap. 6. Remove B-terminal nut. 7. Remove B-terminal lead. Прикрепленный файл  1 copy.jpg   29.5К   17 Количество загрузок: 8. Disconnect the generator's L- and S-terminal connectors. 9. Loosen pivot bolt and tensioner mounting bolt. Do not remove. Прикрепленный файл  2 copy.jpg   47.9К   16 Количество загрузок: 10. Relieve tension on drive belt by rotating adjustment bolt. 11. Remove drive belt from generator pulley. 12. Remove tensioner mounting bolt and belt tensioner. 13. Remove generator pivot bolt. 14. Loosen bolt at base of adjusting bracket and rotate the bracket up. 15. Lift generator from engine compartment.
#2 getAway Re: генератор
  • 4010 сообщений
Отправлено 19 September 2012 - 16:07
INSTALLATION
Position generator on engine.
Install, but leave loose, pivot bolt.
Rotate bracket down into position on top of generator.
4.
Place belt tensioner into position on adjustment bracket.
5.
Install tensioner mounting bolt, leave loose.
6.
Place drive belt on generator pulley.
7.
Adjust belt tension by rotating adjustment bolt.
Allow deflectiom :
New belt : 0.23-0.31in (6-8mm)
Old belt : 0.28-0.35in (7-9mm)
Прикрепленный файл  1 copy.jpg   30.9К   13 Количество загрузок:
8.
Tighten tensioner bolt.
Tighten tensioner bolt to 14-19lb·ft (19-26N·m).
9.
Tighten pivot bolt and bracket bolt.
Tighten pivolt bolt to 28-38lb·ft (38-51N·m).
10.
Connect generator L- and S-terminal connectors.
11.
Connect B-terminal lead.
12.
Install and tighten B-terminal nut.
13.
Close B-terminal nut cover.
14.
Install air intake inlet pipe and tighten end clamp.
15.
Connect top hose to resonance chamber.
16.
Install front air intake inlet pipe bolts.
17.
Connect negative battery cable.
Be sure the battery connections are not reversed. This will damage the rectifier.
Do not use high voltage testers, such as a megger. They will damage the rectifier.
Remember that battery voltage is always applied to the alternator B-terminal.
Do not ground the L-terminal while the engine is running.
Do not start the engine while the coupler is disconnected from the L- and S-terminals.
#3 krionika Re: генератор
Отправлено 12 November 2007 - 09:00
Генератор Киа Спортейдж AL бензин
Прикрепленный файл  Генератор Киа Спортейдж AL.gif   14.24К   0 Количество загрузок:
#4 krionika Re: генератор
Отправлено 10 January 2015 - 20:40
Генератор дает зарядку при оборотах 2300-2400, если ниже обороты, то нет. Не горит контрольная лампа зарядки на щитке. При включении зажигания не горит символ аккумулятора. Измерял тестером.
Спортаж какой? Что с натяжением ремнем генератора?
#5 *Гость* Re: генератор
Отправлено 10 January 2015 - 21:45
2000 года, бензиновый двигатель, АКПП. С ремнем всё нормально.
#6 *Гость* Re: генератор
Отправлено 10 January 2015 - 21:46
*Сергей*
#7 krionika Re: генератор
Отправлено 11 January 2015 - 11:52
тогда скорее всего замена генератора, вышел из строя диодный мост
Ещё обсуждения по киа спортейдж 1 al на MyKia.club:
