Моменты затяжек сцепления Kia Picanto 1 (SA)
Item | Nm | kgf.m | lb-ft |
Clutch pedal to pedal support member (Clutch pedal bracket) |
17 ~ 26 | 1.7 ~ 2.6 | 12.3~ 18.8 |
Clutch pedal support member to master cylinder (Diesel) | 9 ~ 14 | 0.9 ~ 1.4 | 6.5 ~ 10.1 |
Clutch tube flare nut (Diesel) | 13 ~ 17 | 1.3 ~ 1.7 | 9.4 ~ 12.4 |
Clutch tube bracket (Diesel) | 9 ~ 14 | 0.9 ~ 1.4 | 6.5 ~ 10.1 |
Clutch release cylinder (Diesel) | 15 ~ 22 | 1.5 ~ 2.2 | 10.9 ~ 16.0 |
Clutch release cylinder union bolt (Diesel) | 25 ~ 35 | 2.5 ~ 3.5 | 18.1 ~ 25.5 |
Clutch cover assembly (6ea) | 15 ~ 22 | 1.5 ~ 2.2 | 10.9 ~ 16.0 |
Ignition lock switch nut (Diesel) | 8 ~ 10 | 0.8 ~ 1.0 | 5.8 ~ 7.3 |
