Распиновка разъемов блока BCM Kia Sorento 2 (XM)
(блок управления электрооборудованием кузова)
с 2010 года
Распиновка разъемов блока BCM Kia Sorento 2 (XM).gif 23.98К
4 Количество загрузок:
CON. | PIN | Description | Active | Remark |
A | 1 | Head Lamp Low RH Output | High | PWM |
2 | Head Lamp High RH Output | High | PWM | |
3 | Power (IPS2 & 3) | Power | ||
4 | Front Fog Lamp Output | High | PWM | |
5 | Tail Lamp RH Output | High | ||
6 | Power (IPS1 & 4) | Power | ||
7 | Tail Lamp LH Output | High | ||
8 | Head Lamp Low LH Output | High | PWM | |
9 | Power (IPS5 & 6) | Power | ||
10 | Head Lamp High LH Output | High | PWM | |
11 | Tail Interior Lamp Output | High | ||
12 | Power (IPS0 & 7) | Power | ||
B | 1 | Power Window Relay Output | Low | Relay |
2 | Ignition2 Switch Input | High | ||
3 | Drl Option Switch Input | Low | ||
4 | Battery Monitoring Input | High | ||
5 | Accessory Switch Input | High | ||
6 | ||||
7 | ||||
8 | Burglar Alarm Horn Relay Output | Low | Relay | |
9 | ||||
10 | Ignition1 Monitoring Input | High | ||
11 | ||||
12 | Tail Gate Release Relay Output | Low | Relay | |
C | 1 | |||
2 | Door Unlock Relay Output | Low | Relay | |
3 | Door Lock Relay Output | Low | Relay | |
4 | ||||
5 | ||||
6 | Wiper Low Relay Output | Low | Relay | |
7 | ||||
8 | Defroster Relay Output | Low | Relay | |
9 | ||||
10 | Hood Open Switch Input | Low | ||
11 | Diagnostic Comm. Line K For Tester | Data | ||
12 | Start Inhibit Relay Output | Low | Relay |
L | 1 | |||
2 | ||||
3 | ||||
4 | Wiper Intermittent Volume | AD | ||
5 | Key Illumination Lamp Output | |||
6 | Rear Left Seatwarmer Switch Input | |||
7 | Rear Washer Switch Input | High | ||
8 | ||||
9 | Auto Light Switch Input | Low | ||
10 | Head Lamp Low Switch Input | Low | ||
11 | Wiper Mist Switch Input | High | ||
12 | Auto Light Sensor Input | AD | ||
13 | Auto Light Sensor Ground | Ground | ||
14 | ||||
15 | Washer Switch Input | High | ||
16 | ||||
17 | Defroster Switch Input | Low | ||
18 | Rear Right Seatwarmer Switch Input | |||
19 | Wiper Intermittent Switch Input | High | ||
20 | ||||
21 | Tail Lamp Switch Input | Low | ||
22 | Rear Left Seatwarmer Relay Output | |||
23 | Rear Wiper Switch Input | High | ||
24 | Rear Right Seatwarmer Relay Output | |||
25 | ALS Power Monitoring Input | High | ||
26 | ||||
M | 1 | Head | ||
2 | Driver Door Unlock Relay Output | Low | Relay | |
3 | ||||
4 | Rear Fog Relay Output | Low | Relay | |
5 | Can Network Communication Line(high) | Data | ||
6 | Can Network Communication Line(Low) | Data | ||
7 | ||||
8 | Key In Switch Input | Low | ||
9 | Head Lamp Washer Switch Input | Low | ||
10 | ||||
11 | ||||
12 | Parking Brake Indicator | Low | ||
13 | Hid Option Switch Input | Low | ||
14 | Rear Fog Lamp Switch Input | Low | ||
15 | ||||
16 | Head Lamp high Switch Input | Low | ||
N | 1 | Room Lamp Output | Low | PWM |
2 | ||||
3 | Head Lamp Washer Realy Output | Low | Relay | |
4 | ||||
5 | Hazard Relay Output | Low | Relay | |
6 | ||||
7 | AV Tail Signal Output | Low | ||
8 | ||||
9 | ||||
10 | Key Solenoid Output | Low | Solenoid | |
11 | Supply Power To Ips For Mhlld | |||
12 | Power Ground2 | Ground | ||
13 | Front Fog Lamp Switch Input | Low | ||
14 | Tx Door Unlock State Signal Output | High | ||
15 | Assist Seat Belt Indicator Output | Low | LED | |
16 | P Position Switch Input | Low | ||
17 | Diagnostic Comm. Line K For Tester | Data | ||
18 | Crash Unlock Signal Input | Low | ||
19 | Buzzer Output | Low | ||
20 | ||||
21 | Manual HLLD Power Output | High | ||
22 | Power Ground1 | Low | Lamp | |
K | 1 | |||
2 | Stop Lamp LH/RH Output | High | ||
3 | Stop Lamp Power | Power | ||
4 | Power Window Lock Switch Input | Low | ||
5 | Rear Right Door Open Switch Input | Low | ||
6 | Low | |||
7 | Rear Left Door Open Switch Input | |||
8 | Parking Brake Switch Input | Low | ||
9 | Driver Door Key Unlock Switch Input | Low | ||
10 | Driver Door Open Switch Input | Low | ||
11 | Tail Gate Out Side Handle Signal Input | Low | ||
12 | IMS Relay Output | Low | Relay | |
13 | Rear Door Actuator Unlock Switch Input | |||
14 | ||||
15 | ||||
16 | ||||
17 | Seat Belt Switch Input | Low | ||
18 | Assist Door Open Switch Input | Low | ||
19 | Tail Gate Open Switch Input | Low | ||
20 | Rear Parking Assist System Switch Input | Pulse | ||
21 | Driver Door Key Lock Switch Input | Low | ||
22 | Rear Wiper Relay Output | Low | Relay | |
23 | Assist Door Actuator Unlock Switch Input | Low | ||
24 | Power Window Unlock Switch Input | Low | ||
25 | Assistant Seat Belt Switch Input | Low | ||
26 | Driver Door Actuator Unlock Switch Input | Low |
