Kia Ceed ED (2006-2012) - замена шруса
REMOVAL
Loosen the wheel nuts slightly.
Raise the vehicle, and make sure it is securely supported.
Remove the front wheel and tire from front hub.
Be careful not to damage to the hub bolts when removing the front wheel and tire.
Remove the split pin (A), then remove castle nut (B) and washer from the front hub under applying the break.
4.
Remove the ball joint assembly mounting bolt (A) from the knuckle.
5.
Remove the tie rod end ball joint from the knuckle.
(1)
Remove the split pin and castle nut.
(2)
Disconnect the ball joint (A) from knuckle by using the special tool (09568-4A000).
