Kia Sportage KM (2005-2010) - замена сцепления
REPLACEMENT 1. Remove the transaxle assembly.(See 'TR' group - 'Manual Transaxle') 2. Insert the special tool (09411-11000) in the clutch disc to prevent the disc from falling. Kia Sportage KM 2005-2010 - замена сцепления (1).jpg 39.66К 10 Количество загрузок: 3. Loosen the bolts which attach the clutch cover to the flywheel in a star pattern. Loosen the bolts in succession, one or two turns at a time, to avoid bending the cover flange. Do not clean the clutch disc or the release bearing with cleaning solvent. Kia Sportage KM 2005-2010 - замена сцепления (2).jpg 42.09К 7 Количество загрузок: 4. Remove the release fork shaft and bushing. 5. Apply multipurpose grease to the spline of the disc. Grease: CASMOLY L 9508 0.2gr When installing the clutch, apply grease to each part, but be careful not to apply excessive grease. It can cause clutch slippage and judder. Kia Sportage KM 2005-2010 - замена сцепления (3).jpg 52.97К 8 Количество загрузок:
