Kia Soul AM (2009+) - замена сцепления
Removal
Remove the transaxle assembly. (Refer to Manual transaxle's removal in MT group)
Insert the special tool (09411-11000) in the clutch disc to prevent the disc from shifting.
Kia Soul AM (2009+) - замена сцепления.jpg 52.98К
8 Количество загрузок:
Loosen the bolts(Gasoline : 6ea, Diesel : 9ea) which attach the clutch cover to the flywheel in a star pattern. Loosen the bolts in succession, one or two turns at a time, to avoid bending the cover.
Do not clean the clutch disc or the release bearing with cleaning solvent.
