29.
Remove the timing chain cover (A).
Be careful not to damage the contact surfaces of cylinder block, cylinder head and timing chain cover.
Before removing the timing chain, mark the RH/LH timing chain with an identification based on the location of the sprocket because the identification mark on the chain for TDC (Top Dead Center) can be erased.
#11
Отправлено 22 October 2012 - 17:19
#12
Re: (VG) Цепь ГРМ
Отправлено 22 October 2012 - 17:20
#13
Re: (VG) Цепь ГРМ
#14
Re: (VG) Цепь ГРМ
#15
Re: (VG) Цепь ГРМ
#16
Re: (VG) Цепь ГРМ
#17
Re: (VG) Цепь ГРМ
Отправлено 23 October 2012 - 14:43
Installation
Install the jack to the edge of upper oil pan to support the engine.
Insert the rubber block between jack and upper oil pan.
The key (A) of crankshaft should be aligned with the timing mark (B) of timing chain cover. As a result of this, the piston of No.1 cylinder is placed at the top dead center on compression stroke.
Install the tensioner adapter assembly (A).
#18
Re: (VG) Цепь ГРМ
Отправлено 23 October 2012 - 14:44
4.
Install the crankshaft sprocket (A). (LH camshaft drive).
5.
Install the LH timing chain guide (A) and LH timing chain (B).
Tightening torque :
19.6 ~ 24.5N.m (2.0 ~ 2.5kgf.m, 14.5 ~ 18.1lb-ft)
To install the timing chain with no slack between each shaft (cam, crank), follow the below procedure.
Crankshaft sprocket ? Timing chain guide ? Exhaust camshaft sprocket ? Intake camshaft sprocket.
The timing mark of each sprockets should be matched with timing mark (color link) of timing chain at installing timing chain.
#19
Re: (VG) Цепь ГРМ
Отправлено 23 October 2012 - 14:45
6.
Install the LH timing chain auto tensioner (A) and LH timing chain tensioner arm (B).
Tightening torque
A : 9.8 ~ 11.8N.m (1.0 ~ 1.2kgf.m, 7.2 ~ 8.7lb-ft)
B : 18.6 ~ 21.6N.m (1.9 ~ 2.2kgf.m, 13.7 ~ 15.9lb-ft)
7.
Install the crankshaft sprocket (A) (O/P & RH camshaft drive).
#20
Re: (VG) Цепь ГРМ
Отправлено 23 October 2012 - 14:46
8.
Install the oil pump chain sprocket (A) and oil pump chain (B).
Tightening torque :
9.
Install the RH timing chain guide (A) and RH timing chain (B).
Tightening torque :
A : 19.6 ~ 24.5N.m (2.0 ~ 2.5kgf.m, 14.5 ~ 18.1lb-ft)
Crankshaft sprocket ?Timing chain guide ? Intake camshaft sprocket ? Exhaust camshaft sprocket.
Ответить
Последние обсуждения по киа каденза на MyKia.club
Киа Каденза
Обсуждение тех. вопросов →
Другие модели Киа →
Киа Каденза клуб →
Все о Kia CadenzaАвтор Nataly Portman , 12 Nov 2015 |
Киа Каденза
Другие модели Киа →
Киа Каденза клуб →
(VG) Система охлажденияАвтор krionika , 12 Jun 2014 |
Киа Каденза
Другие модели Киа →
Киа Каденза клуб →
(VG) Масло и фильтр для двигателяАвтор getAway , 18 Mar 2013 |
faq
Другие модели Киа →
Киа Каденза клуб →
Масло для АКПП Kia Cadenza VGАвтор getAway , 11 Mar 2013 ![]() |
Киа Каденза
Другие модели Киа →
Киа Каденза клуб →
(VG) БамперАвтор getAway , 04 Dec 2012 |
