Kia Cadenza VG (2010+) - замена цепи ГРМ, метки
Removal
Use fender covers to avoid damaging painted surfaces.
To avoid damage, unplug the wiring connectors carefully while holding the connector portion.
Mark all wiring and hoses to avoid misconnection.
Disconnect the battery negative terminal (A).
Remove the engine cover (B).
Remove the air duct ©.
4.
Disconnect the battery positive terminal, and then remove the battery (A).
5.
Disconnect the breather hose (A) and the BARO (Barometric pressure) sensor connector (B).
6.
Remove the air intake hose clamp ©, and then remove the air cleaner assembly (D).
