Киа Спортейдж 2 KM
кондиционер
  • 4017 сообщений
Отправлено 11 October 2012 - 13:05
Kia Sportage KM (2005-2010) - снятие и установка радиатора кондиционера
Replacement 1. Recover the refrigerant with a recovery/recycling/charging station (See page HA-10). 2. Remove the coolant reservoir, but do not disconnect the reservoir hose from the coolant reservoir and the radiator (? Engine). 3. Remove the battery ( D Engine). 4. Remove the bolt(A), then remove the radiator bracket(B) from the radiator. Прикрепленный файл  1 copy.jpg   36.42К   9 Количество загрузок: 5. Remove the nuts (A), then disconnect the discharge line and condenser line from the condenser. Plug or cap the lines immediately after disconnecting them to avoid moisture and dust contamination. Прикрепленный файл  2 copy.jpg   34.08К   10 Количество загрузок: 6. Remove the bolts (A), then remove the condenser (B) by lifting it up. Be careful not to damage the radiator and condenser fins when removing the condenser. Прикрепленный файл  3 copy.jpg   27.37К   6 Количество загрузок: 7. Install in the reverse order of removal, and note these items: A. If you're installing a new condenser, add refrigerant oil ND-OIL8. B. Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. C. Be careful not to damage the radiator and condenser fins when installing the condenser. D. Be sure to install the lower mount cushions of condenser securely into the holes. E. Charge the system, and test its performance.
#2 getAway Re: кондиционер
  • 4017 сообщений
Отправлено 19 October 2012 - 15:54
Kia Sportage KM (2005-2010) - снятие и установка компрессора кондиционера
Removal 1. If the compressor is marginally operable, run the engine at idle speed, and let the air conditioning work for a few minutes, then shut the engine off. 2. Disconnect the negative cable from the battery. 3. Recover the refrigerant with a recovery/charging station (See page HA-10). 4. Loosen the drive belt (See page HA-22). 5. Remove the bolts, then disconnect the suction line (A) and discharge line (B) from the compressor. Plug or cap the lines immediately after disconnecting them to avoid moisture and dust contamination. Прикрепленный файл  1 copy.jpg   31.78К   11 Количество загрузок: 6. Disconnect the compressor clutch connector (A), then remove the mounting bolts and the compressor (B). Прикрепленный файл  2 copy.jpg   37.19К   8 Количество загрузок:
#3 getAway Re: кондиционер
  • 4017 сообщений
Отправлено 19 October 2012 - 15:55
Installation
<table border="0" cellpadding="0" cellspacing="0" style="width:100%;padding-bottom:6;"> <tbody> <tr> <td style="padding-left:3px;" valign="top" width="12"> 1.</td> <td style="padding-left:3px;" valign="top">
Make sure of the length of compressor mounting bolts, and then tighten it A?B?C?D order. <table border="1" cellpadding="3" cellspacing="0" style="border:solid 1pt gray;BORDER-COLLAPSE: collapse;bgcolor=#ccffff;width:100%;MARGIN-top: 5px;"> <tbody> <tr> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="10%%"> Bolt</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> D Engine</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> ? Engine</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> ? Engine</td> </tr> <tr> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="10%%"> A</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 118mm (4.65in.)</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 118mm (4.65in.)</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 118mm (4.65in.)</td> </tr> <tr> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="10%%"> B</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 118mm (4.65in.)</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 102mm (4.02in.)</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 118mm (4.65in.)</td> </tr> <tr> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="10%%"> C</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 102mm (4.02in.)</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 102mm (4.02in.)</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 118mm (4.65in.)</td> </tr> <tr> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="10%%"> D</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 94mm (3.70in.)</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 126mm (4.96in.)</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="30%%"> 94mm (3.70in.)</td> </tr> </tbody> </table>
Прикрепленный файл  1 copy.jpg   28.8К   10 Количество загрузок: </td> </tr> </tbody></table><table border="0" cellpadding="0" cellspacing="0" style="width:100%;padding-bottom:6;"> <tbody> <tr> <td style="padding-left:3px;" valign="top" width="12"> 2.</td> <td style="padding-left:3px;" valign="top">
Install in the reverse order of removal, and note these items. <table border="0" cellpadding="0" cellspacing="1" width="100%"> <tbody> <tr> <td align="right" style="width:15px;" valign="top"> A.</td> <td style="padding-left:3px;" valign="top">
If you're installing a new compressor, drain all the refrigerant oil from the removed compressor, and measure its volume, Subtract the volume of drained oil from 120cc(4.20 oz.) the result is the amount of oil you should drain from the new compressor (through the suction fitting). </td> </tr> </tbody> </table> <table border="0" cellpadding="0" cellspacing="1" width="100%"> <tbody> <tr> <td align="right" style="width:15px;" valign="top"> B.</td> <td style="padding-left:3px;" valign="top">
Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. </td> </tr> </tbody> </table> <table border="0" cellpadding="0" cellspacing="1" width="100%"> <tbody> <tr> <td align="right" style="width:15px;" valign="top"> C.</td> <td style="padding-left:3px;" valign="top">
To avoid contamination, do not return the oil to the container once dispensed, and never mix it with other refrigerant oils. </td> </tr> </tbody> </table> <table border="0" cellpadding="0" cellspacing="1" width="100%"> <tbody> <tr> <td align="right" style="width:15px;" valign="top"> D.</td> <td style="padding-left:3px;" valign="top">
Immediately after using the oil, replace the cap on the container and seal it to avoid moisture absorption. </td> </tr> </tbody> </table> <table border="0" cellpadding="0" cellspacing="1" width="100%"> <tbody> <tr> <td align="right" style="width:15px;" valign="top"> E.</td> <td style="padding-left:3px;" valign="top">
Do not spill the refrigerant oil on the vehicle; it may damage the paint; if the refrigerant oil contacts the paint, wash it off immediately. </td> </tr> </tbody> </table> <table border="0" cellpadding="0" cellspacing="1" width="100%"> <tbody> <tr> <td align="right" style="width:15px;" valign="top"> F.</td> <td style="padding-left:3px;" valign="top">
Adjust the drive belt (See page HA-22). </td> </tr> </tbody> </table> <table border="0" cellpadding="0" cellspacing="1" width="100%"> <tbody> <tr> <td align="right" style="width:15px;" valign="top"> G.</td> <td style="padding-left:3px;" valign="top">
Charge the system and test its performance. </td> </tr> </tbody> </table> </td> </tr> </tbody></table>
Ещё обсуждения по киа спортейдж 2 km на MyKia.club:
