Kia Soul AM (2009+) - снятие и установка радиатора кондиционера
Replacement
Condenser Assembly
Recover the refrigerant with a recovery/ recycling/ charging station .
Disconnect the negative (-) battery terminal.
Remove the front bumper. (Refer to BD group-front bumper)
4.
Disconnect the refrigerant line(A).
1 copy.jpg 39.88К
10 Количество загрузок:
5.
Remove the mount bumper(A).
2 copy.jpg 36.5К
9 Количество загрузок:
6.
Remove the condenser (A) by lifting it up. Be careful not to damage the radiator and condenser fins when removing the condenser.
3 copy.jpg 43.53К
7.
Install in the reverse order of removal, and note these items :
A.
If you're installing a new condenser, add refrigerant oil ND-OIL8.
B.
Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage.
C.
Be careful not to damage the radiator and condenser fins when installing the condenser.
D.
Be sure to install the lower mount cushions of condenser securely into the holes.
E.
Charge the system, and test its performance.
Desiccant
Replacement
Remove the condenser, and then remove the bottom cap (B) with L wrench (A) from the condenser.
4 copy.jpg 23.26К
8 Количество загрузок:
TORQUE : 20~25N.m (2.0~2.5kgf•m, 14.5~18.2lb-ft)
Remove the desiccant (A) from condenser using a long nose plier. Check for crumbled desiccant and clogged bottom cap filter.
5 copy.jpg 22.53К
Apply air conditioning compressor oil along the O-rings and threads of the new bottom cap.
4.
Insert the new desiccant into the receiver drier tank. The desiccant must be sealed in vacuum before it is exposed to air for use.
5.
Install the new bottom cap to the condenser.
Always replace the desiccant and bottom cap at the same time.
