Киа Соренто 2 XM
кондиционер
Сообщений в теме: 4
  • 4013 сообщений
Отправлено 11 October 2012 - 12:54
Kia Sorento XM (2009+) - снятие и установка радиатора кондиционера
Replacement 1. Recover the refrigerant with a recovery/ recycling/ charging station . 2. Disconnect the negative (-) battery terminal. 3. Remove the front bumper(Refer to BD group - Front Bumper) 4. Remove 2 nuts, and then disconnect the discharge line and liquid line (A) from the condenser. Прикрепленный файл  1 copy.jpg   37.88К   15 Количество загрузок: 5. Remove the condenser cover (A). Прикрепленный файл  2 copy.jpg   36.91К   18 Количество загрузок: 6. Remove the radiator assembly(Refer to EM group - Radiator) 7. Remove the condenser(A) from radiator. Прикрепленный файл  3 copy.jpg   66.63К   19 Количество загрузок: 8. Install in the reverse order of removal, and note these items : A. If you're installing a new condenser, add refrigerant oil ND-OIL8. B. Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. C. Be careful not to damage the radiator and condenser fins when installing the condenser. D. Be sure to install the lower mount cushions of condenser securely into the holes. E. Charge the system, and test its performance.
#2 getAway Re: кондиционер
  • 4013 сообщений
Отправлено 19 October 2012 - 15:43
Kia Sorento XM (2009+) - снятие и установка компрессора кондиционера Removal 1. If the compressor is marginally operable, run the engine at idle speed, and let the air conditioning work for a few minutes, then shut the engine off. 2. Disconnect the negative cable from the battery. 3. Recover the refrigerant with a recovery/charging station*. 4. Loosen the drive belt. 5. Remove the bolts, then disconnect the suction line (A) and discharge line (B) from the compressor. Plug or cap the lines immediately after disconnecting them to avoid moisture and dust contamination. Прикрепленный файл  1 copy.jpg   37.04К   9 Количество загрузок: 6. Disconnect the compressor clutch connector (B), and then remove 3 mounting bolts and the compressor. Прикрепленный файл  2 copy.jpg   38.05К   7 Количество загрузок:
#3 getAway Re: кондиционер
  • 4013 сообщений
Отправлено 19 October 2012 - 15:45
Installation
Make sure of the length of compressor mounting bolts, and then tighten it A?B?C order.
Torque:
20.0~32.9N.m (2.04~3.36kgf.m, 14.7~24.3lb-ft)
[Diesel Engine]
Прикрепленный файл  1 copy.jpg   38.47К   8 Количество загрузок:
[Gasoline Engine]
Прикрепленный файл  2 copy.jpg   40.69К   10 Количество загрузок:
Install in the reverse order of removal, and note these items.
A.
If you're installing a new compressor, drain all the refrigerant oil from the removed compressor, and measure its volume, Subtract the volume of drained oil from 120cc(4.20 oz.) the result is the amount of oil you should drain from the new compressor (through the suction fitting).
B.
C.
To avoid contamination, do not return the oil to the container once dispensed, and never mix it with other refrigerant oils.
D.
Immediately after using the oil, replace the cap on the container and seal it to avoid moisture absorption.
E.
Do not spill the refrigerant oil on the vehicle; it may damage the paint; if the refrigerant oil contacts the paint, wash it off immediately.
F.
Adjust the drive belt.
G.
Charge the system and test its performance.
#4 *Макс* Re: кондиционер
*Макс*
Отправлено 19 April 2021 - 15:56
а сколько хладагента надо заправлять в кондишен? знает кто? соренто XM 2.4 бензин
#5 Эдельвейс Re: кондиционер
Эдельвейс
  • 493 сообщений
Отправлено 19 April 2021 - 17:27
*Макс*
Без заднего A/C 600 ± 25g
C задним  A/C 750 ± 25g
Люблю грозу в начале Мая... :cb9:
Ещё обсуждения по киа соренто 2 xm на MyKia.club:
