Киа Рио 1 BC
кондиционер
  • 4013 сообщений
Отправлено 11 October 2012 - 12:34
киа рио 1 (BC)
Kia Rio BC (2000-2006) - снятие и установка радиатора кондиционера
REMOVAL 1. Discharge refrigeration system. (Refer to operating instructions of your refrigerant recovery/recycling/ charging station for proper procedures.) 2. Remove liquid pipes. 3. Remove condenser as shown in figure. 1. Insert protector such as cardboard between condenser and radiator. 2. Immediately plug open fittings to keep moisture out of system.
#2 getAway Re: кондиционер
  • 4013 сообщений
Отправлено 11 October 2012 - 12:35
INSTALLATION
Install condenser in reverse order of removal.
Apply clean compressor oil to O-rings before connecting fittings.
Do not apply compressor oil to fitting nuts.
Remove protector before installing radiator brackets.
4.
When installing a new condenser, add compressor oil through high-pressure pipe port of compressor. Compressor oil: 1.22 cu in (20 cc)
Tightening torque:
Condenser inlet : 87~174 lb-in
(9.8~19.6 N·m, 1.0~2.0 kg-m)
#3 getAway Re: кондиционер
  • 4013 сообщений
Отправлено 19 October 2012 - 15:20
Kia Rio BC (2000-2006) - снятие и установка компрессора кондиционера
REMOVAL AND INSTALLATION 1. Loosen the tension pulley tightening bolt A, and then remove the drive belt after loosening the tension adjusting bolt B. (Without power steering) Loosen the bolt A,B,C and then remove the drive belt after loosening the tension adjusting bolt D. (With power steering) 2. Discharge the refrigerant. 3. Remove the discharge and suction hoses. 4. Remove the compressor. Прикрепленный файл  1 copy.jpg   23.11К   8 Количество загрузок: 5. Installation is the reverse of removal. Tightening torque 24~36 N·m (2.4~3.6 kg-m, 17~26 Ib·ft)
Ещё обсуждения по киа рио 1 bc на MyKia.club:
