Киа Опирус GH
кондиционер (общие вопросы)
  • 3954 сообщений
Отправлено 11 October 2012 - 12:01
Kia Opirus GH (2004-2010) - снятие и установка радиатора кондиционера
Replacement 1. Recover the refrigerant with a recovery/ recycling/ charging station . 2. Disconnect the negative (-) battery terminal. 3. Remove the front bumper(Refer to BD group-front bumper) 4. 4. Remove the radiator assembly(Refer to EM group-radiator) 5. Remove the condenser(A) from radiator.   6. Install in the reverse order of removal, and note these items : A. If you're installing a new condenser, add refrigerant oil ND-OIL8. B. Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. C. Be careful not to damage the radiator and condenser fins when installing the condenser. D. Be sure to install the lower mount cushions of condenser securely into the holes. E. Charge the system, and test its performance. Desiccant Replacement 1. Remove the condenser, and then remove the bottom cap (B) with L wrench (A) from the condenser.   TORQUE : 22.5~32.3N.m (2.3~3.3kgf•m, 16.6~23.8lb-ft) 2. Remove the desiccant (A) from condenser using a long nose plier. Check for crumbled desiccant and clogged bottom cap filter.   3. Apply air conditioning compressor oil along the O-rings and threads of the new bottom cap. 4. Insert the new desiccant into the receiver drier tank. The desiccant must be sealed in vacuum before it is exposed to air for use. 5. Install the new bottom cap to the condenser. - Always replace the desiccant and bottom cap at the same time. - Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. - Be careful not to damage the radiator and condenser fins when installing the condenser. - Be sure to install the lower mount cushions of condenser securely into the holes. - Charge the system, and test its performance.
#2 getAway Re: кондиционер (общие вопросы)
  • 3954 сообщений
Отправлено 18 October 2012 - 17:13
Kia Opirus GH (2004-2010) - снятие и установка компрессора кондиционера
REMOVAL 1. Discharge the refrigerant. 2. Remove the drive belt after loosening the tension pulley. 3. Remove the discharge and suction hoses. 4. Disconnect the connector 5. Remove the compressor. Прикрепленный файл  1 copy.jpg   23.42К   11 Количество загрузок: • Plug the all open fittings immediately to keep moisture out of the system. • Do not remove plugs until ready for connection. • Evacuate, charge and test the refrigeration system.
#3 getAway Re: кондиционер (общие вопросы)
  • 3954 сообщений
Отправлено 18 October 2012 - 17:14
Installation
Make sure of the color of compressor mounting bolts, and then tighten it A?B?C?D order
Прикрепленный файл  1 copy.jpg   25.31К   10 Количество загрузок:
Set the tension of belt after installation.
Последние обсуждения по Киа Опирус GH на MyKia.club
