Киа Сид 1 ED
кондиционер
  • 4010 сообщений
Отправлено 10 October 2012 - 16:41
киа сид 1 (ED)
Kia Ceed ED (2006-2012) - снятие и установка радиатора кондиционера
REPLACEMENT CONDENSER ASSEMBLY 1. Recover the refrigerant with a recovery/ recycling/ charging station. 2. Disconnect the negative (-) battery terminal. 3. Remove 2 nuts (A), and then disconnect the discharge line and liquid line from the condenser. Plug or cap the lines immediately after disconnecting them to avoid moisture and dust contamination. TORQUE: 7.8~11.7N.m (0.8~1.2kgf.m, 5.9~8.7lb.ft) Прикрепленный файл  1 copy.jpg   37.98К   11 Количество загрузок: 4. Remove the radiator (A). (Refer to EM group - Radiator) 5. Remove 2 bolts, and then remove the condenser by lifting it up. Be careful not to damage the radiator and condenser fins when removing the condenser (B). Прикрепленный файл  2 copy.jpg   42.34К   11 Количество загрузок: 6. Install in the reverse order of removal, and note these items : A. If you're installing a new condenser, add refrigerant oil ND-OIL8. B. Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. C. Be careful not to damage the radiator and condenser fins when installing the condenser. D. Charge the system, and test its performance. DESICCANT 1. Remove the condenser, and then remove the bottom cap (B) with L wrench (A) from the condenser. TORQUE: 10~15 N.m (1.0~1.5 kgf.m, 7.23~10.84 lb.ft) Прикрепленный файл  3 copy.jpg   22.73К   7 Количество загрузок: 2. Remove the desiccant (A) from condenser using a long nose plier. Check for crumbled desiccant and clogged bottom cap filter. Прикрепленный файл  4 copy.jpg   22.28К   8 Количество загрузок: 3. Apply air conditioning compressor oil along the O-rings and threads of the new bottom cap. 4. Insert the new desiccant into the receiver drier tank. The desiccant must be sealed in vacuum before it is exposed to air for use. 5. Install the new bottom cap to the condenser. - Always replace the desiccant and bottom cap at the same time. - Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. - Be careful not to damage the radiator and condenser fins when installing the condenser. - Charge the system, and test its performance.
#2 getAway Re: кондиционер
  • 4010 сообщений
Отправлено 18 October 2012 - 16:50
Kia Ceed ED (2006-2012) - снятие и установка компрессора кондиционера
REMOVAL 1. If the compressor is marginally operable, run the engine at idle speed, and let the air conditioning work for a few minutes, then shut the engine off. 2. Disconnect the negative cable from the battery. 3. Recover the refrigerant with a recovery/charging station. 4. Loosen the drive belt. 5. Remove the bolts, then disconnect the suction line (A) and discharge line (B) from the compressor. Plug or cap the lines immediately after disconnecting them to avoid moisture and dust contamination. Прикрепленный файл  1 copy.jpg   26.91К   9 Количество загрузок: 6. Disconnect the compressor clutch connector, and then remove 4 mounting bolts and the compressor (A). Прикрепленный файл  2 copy.jpg   44.2К   9 Количество загрузок:
#3 getAway Re: кондиционер
  • 4010 сообщений
Отправлено 18 October 2012 - 16:51
INSTALLATION
Make sure of the length of compressor mounting bolts, and then tighten it A?B?C?D order.
Bolt
R,U,D Engine
? Engine
A
100 mm (3.93 in.)
125 mm (4.92in.)
B
100 mm (3.93in.)
109 mm (4.29in.)
C
109 mm (4.29in.)
125 mm (4.92in.)
D
100 mm (3.93in.)
109 mm (4.29in.)
Прикрепленный файл  1 copy.jpg   30.34К   9 Количество загрузок:
Install in the reverse order of removal, and note these items.
A.
If you're installing a new compressor, drain all the refrigerant oil from the removed compressor, and measure its volume, Subtract the volume of drained oil from 150cc(5.07 oz.) the result is the amount of oil you should drain from the new compressor (through the suction fitting).
B.
C.
To avoid contamination, do not return the oil to the container once dispensed, and never mix it with other refrigerant oils.
D.
Immediately after using the oil, replace the cap on the container and seal it to avoid moisture absorption.
E.
Do not spill the refrigerant oil on the vehicle; it may damage the paint; if the refrigerant oil contacts the paint, wash it off immediately.
F.
Adjust the drive belt.
G.
Charge the system and test its performance.
Ещё обсуждения по киа сид 1 ed на MyKia.club:
