Киа Каренс 2 UN
кондиционер
  • 4013 сообщений
Отправлено 10 October 2012 - 15:02
Kia Carens UN (2006-2011) - снятие и установка радиатора кондиционера
REPLACEMENT CONDENSER ASSEMBLY 1. Recover the refrigerant with a recovery/ recycling/ charging station (Refer to HA-8). 2. Disconnect the negative (-) battery terminal. 3. Remove the refrigerant line(A). Прикрепленный файл  1 copy.jpg   31.47К   12 Количество загрузок: 4. Remove the front bumper radiator grill cover (A). Прикрепленный файл  2 copy.jpg   44.09К   13 Количество загрузок: 5. Remove the radiator. (Refer to EM group-radiator). 6. Remove the condenser (A) by lifting it up. Be careful not to damage the radiator and condenser fins when removing the condenser. Прикрепленный файл  3 copy.jpg   45.33К   14 Количество загрузок: 7. Install in the reverse order of removal, and note these items : A. If you're installing a new condenser, add refrigerant oil ND-OIL8. B. Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. C. Be careful not to damage the radiator and condenser fins when installing the condenser. D. Be sure to install the lower mount cushions of condenser securely into the holes. E. Charge the system, and test its performance. DESICCANT 1. Remove the condenser, and then remove the bottom cap (B) with L wrench (A) from the condenser. TORQUE: 20~25N.m (2.0~2.5kgf·m, 14.5~18.2lb-ft) Прикрепленный файл  4 copy.jpg   22.75К   14 Количество загрузок: 2. Remove the desiccant (A) from condenser using a long nose plier. Check for crumbled desiccant and clogged bottom cap filter. Прикрепленный файл  5 copy.jpg   22.28К   13 Количество загрузок: 3. Apply air conditioning compressor oil along the O-rings and threads of the new bottom cap. 4. Insert the new desiccant into the receiver drier tank. The desiccant must be sealed in vacuum before it is exposed to air for use. 5. Install the new bottom cap to the condenser. - Always replace the desiccant and bottom cap at the same time. - Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. - Be careful not to damage the radiator and condenser fins when installing the condenser. - Be sure to install the lower mount cushions of condenser securely into the holes. - Charge the system, and test its performance.
#2 getAway Re: кондиционер
  • 4013 сообщений
Отправлено 18 October 2012 - 16:36
Kia Carens UN (2006-2011) - снятие и установка компрессора кондиционера REMOVAL 1. If the compressor is marginally operable, run the engine at idle speed, and let the air conditioning work for a few minutes, then shut the engine off. 2. Disconnect the negative cable from the battery. 3. Recover the refrigerant with a recovery/charging station (Refer to HA-8). 4. Loosen the drive belt (Refer to EM group-drive belt). 5. Remove the bolts, then disconnect the suction line and discharge line from the compressor. Plug or cap the lines immediately after disconnecting them to avoid moisture and dust contamination. 6. Disconnect the compressor clutch connector (A), and then remove 4 mounting bolts and the compressor. Прикрепленный файл  1 copy.jpg   42.22К   11 Количество загрузок:
#3 getAway Re: кондиционер
  • 4013 сообщений
Отправлено 18 October 2012 - 16:38
INSTALLATION
Make sure of the length of compressor mounting bolts, and then tighten it A?B?C?D order.
Bolt Color length
A
Yellow
102mm
B
Yellow
102mm
C
Yellow
102mm
D
Yellow
102mm
Прикрепленный файл  1 copy.jpg   31.42К   9 Количество загрузок:
Install in the reverse order of removal, and note these items.
A.
If you're installing a new compressor, drain all the refrigerant oil from the removed compressor, and measure its volume, Subtract the volume of drained oil from 120cc(4.20 oz.) the result is the amount of oil you should drain from the new compressor (through the suction fitting).
B.
C.
To avoid contamination, do not return the oil to the container once dispensed, and never mix it with other refrigerant oils.
D.
Immediately after using the oil, replace the cap on the container and seal it to avoid moisture absorption.
E.
Do not spill the refrigerant oil on the vehicle; it may damage the paint; if the refrigerant oil contacts the paint, wash it off immediately.
F.
Adjust the drive belt. (Refer to HA-14)
G.
Charge the system and test its performance.
Ещё обсуждения по киа каренс 2 un на MyKia.club:
